RV.Net Open Roads Forum: Tech Issues: Skylight crack repair
 > Skylight crack repair
D.E.Bishop
Eagle Rock, CA
Posted: 02/09/19 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone here attempted to weld a cracked skylight made of polycarbonate? I finally found a new dome but if I can fix it for a few cents instead of $140 plus shipping for a new dome, it would be worth it.
I have a hot air type welder and the correct rods as I've done repairs on other items. I will drill a stop crack hole first and then weld. One crack is where a mounting screw is located and I'll weld and then install a new screw on either side of the crack.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
95 Suzuki Sidekick 4X4
Stowmaster 5000
Home Skillet
Pearland Texas
Posted: 02/09/19 10:22am Link  |  Quote  |  Print  |  Notify Moderator
It's hard to plastic weld polycarbonate. Not enough flex in the material.
I just put a strip of EternaBond on mine.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
gbopp
The Keystone State
Posted: 02/09/19 10:35am Link  |  Quote  |  Print  |  Notify Moderator
I stop drilled mine and applied a strip of Eternabond. It's been several years and no leaks or problems.
PenMan
New Mexico
Posted: 02/09/19 10:46am Link  |  Quote  |  Print  |  Notify Moderator
I just replaced mine. It had several cracks in it.
Chris and Jane
2013 Open Range Journeyer JT337RLS
2006 Dodge Ram 3500, 4x4, Crew Cab, DRW, 5.9 turbo diesel
1996 Harley Davidson Electraglide
IB853347201
Eastern Ontario
Posted: 02/09/19 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
$140? What a deal. I would definately just replace it as fast as you can. Water damage from a crack/leak will cause more than $140 damage in the blink of an eye..
mobeewan
Hampton, Va
Posted: 02/09/19 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have some water damage due to cracks where the Dome transitions into the flanges. I didn't realize it until water dripped on my head while I was taking a shower. The water was running down the roof framing and then wicked its way on top of the ceiling paneling spreading out.
You really need to go ahead and replace it now while you can before you have a lot of water damage and have to start tearing into the roof. A temporary fix would be to put some Eternal Bond over the cracks. That would have least stop any possible water from getting through if it hasn't been already.
loggenrock
New Hampshire
Posted: 02/09/19 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Consider Lexel - got it at Home Depot. Crystal clear non-silicone caulk/sealant. Very flexible. About $7 for a small tube. Can't speak for long term durability - only started using it last summer, but very good results so far.
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
Cummins12V98
on the road
Posted: 02/10/19 06:08am Link  |  Quote  |  Print  |  Notify Moderator
Replace it, WHY risk potential water damage over 140 bones???
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
larry barnhart
wenatchee. wa usa
Posted: 02/10/19 08:56am Link  |  Quote  |  Print  |  Notify Moderator
That is what I did in July because of a hairline crack that dicor fixed it to wait to get home last winter. Time and sun on a 2001 was the reason.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
D.E.Bishop
Eagle Rock, CA
Posted: 02/12/19 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Well Folks, I am following the replace it posts, not because I want to but because there are quite a few cracks and several, maybe thousands of little hairline fractures just waiting for a little twisting or a tree limb or maybe even a gull to land on the dome.
I am skipping on the $140, plus shipping and buying from Lichtsinn. It's $11 more but I know that it is an exact replacement for the original dome.
I am not however going to use the same adhesive that Winnie used. It nay work but not applied the way the factory used it. There is some damage to the roof substrate and in part it was cause by the adhesive being installed in a very narrow area and not adhering well.
The roof is fiberglass laid over luan and foam under the roof. The foam is not glued to the luan. A small area if the luan has delaminated and I have a excellent waterproof adhesive that I will use to glue the lams back together. The glue is from a mill in Oregon and is used to laminate beams. I have some 1.5" by .125" mild steel that I intend to put between the luan and the foam. I will drill holes for mounting in the steel and use sheet metal screw to put the skylight, fiberglass and luan tight together and give the screws a better bite that just the glass and luan. I'l start work nextweek after this current storm has past, I'll post some pictures whan I'm done.
