RV.Net Open Roads Forum: Fifth-Wheels: Setting Up Tow Vehicle w/hitch, Etc
 > Setting Up Tow Vehicle w/hitch, Etc
MudChucker
Niverville Manitoba
Posted: 02/10/19 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, buy the wedge kit and put the plug inside the bed, save your tail gate from the wire rub rash.
2017 Cougar
2015 Ram 3500 Megacab 6.7 Cummins Aisin transmission
Cummins12V98
on the road
Posted: 02/11/19 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Super_Dave wrote:
garyp4951 wrote:
Don't forget the wiring harness for inside the bed. etrailer.com
I've always used the bumper plug for mine.
HA, I used to do that also. Then one day coming off a long offramp I had NO brakes. My cable had pulled out somehow. NOT a good feeling.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Al H
56472
Posted: 02/11/19 08:48am Link  |  Quote  |  Print  |  Notify Moderator
good point on inside box wiring and receptacle. We have a shop truck that we pull a gooseneck trailer but we always have the tailgate off so no big deal plugging in. With tailgate the cord would have to be long
rhagfo
Portland, OR
Posted: 02/11/19 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Al H wrote:
Looking at buying a 3500 Ram Mega Cab with short box and wondering if this may be problem towing a fifth wheel trailer. Is a special hitch required so the cab does not hit the trailer? Also about how much would it cost to set up the truck with hitch, wiring, etc? I would install myself but what is an approximate cost for hitch and related parts? The truck does not have the goose neck hitch set up option, only the class 4 hitch and wiring.
Thanks!
Buying New or used?
If buying new get 5th wheel prep, you have pucks and wiring in bed already. Mega cab only has a 6' bed, as a Park Host have seen several with dented cabs, and broken rear windows.
If buying used you may find one with those options. If used how new, Ram changed most of their GVWR numbers big time in 2013, something to think of. The link below will help with the hunt new or used, it will provide the build sheet with GVWR, axle ratio, and transmission besides other information.
Ram VIN decoder
donn0128 wrote:
Sadly with the mega cab configuration you end up with a short short bed. Once you get past the weight issues trying to find a hitch that might work could be a choir. The 3500 mega realisticslly has the load capacity of a quad 2500. Picking carefully a mega can be a good tow vehicle.
Donn, since 2013 the Mega cab 3500 DRW has a GVWR of 14,000#, I know before 2013 the GVWR was like 10,500!!
laknox
Arizona
Posted: 02/11/19 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Or from having the cord slip over the corner of the bed and rip out the 7-way from the bumper. Had this happen TWICE with my GN trailer. After the 2nd time, I had my truck in the hitch shop the next week for the in-bed plug.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 61 Year Member
MudChucker
Niverville Manitoba
Posted: 04/01/19 04:35am Link  |  Quote  |  Print  |  Notify Moderator
Btw I have the mega cab... I've never had to slide my hitch. If you buy the ram box you will need the sidewinder hitch that pivots at the pin box and not in the truck.
rhagfo
Portland, OR
Posted: 04/01/19 07:05am Link  |  Quote  |  Print  |  Notify Moderator
I have seen a couple of Mega cabs with dented cabs.
cummins2014
Utah
Posted: 04/01/19 10:41am Link  |  Quote  |  Print  |  Notify Moderator
I too have the Mega cab, towed with both a slider, and the Andersen. No issues with either, and no dented cab. A reminder to you, the Ram shortbed length is the same in a crew cab as it is in the mega cab. 2500's or 3500's , no difference. I too have never had to slide my hitch back. I have seen dented cabs in other brands of trucks, granted the Rams are the shortest of the three short beds
So if you are seeing dented mega cabs ,you could very well see the same on the crew cab Ram short beds .
laknox
Arizona
Posted: 04/01/19 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Al H wrote:
wvcampers wrote:
My SIL uses the Andersen Ultimate with his Magacab short bed. He is towing a Heartland Sundance with no problems.
Thanks for the information so far, I researched the Anderson Ultimate and really like it. Cost is about $700 for the hitch, chains if needed are another $90. Also found the B&W ball mount at about $500 so $1200-$1300 is about the cost plus installation which I can handle, probably take a half day or so.
I'm a B&W fanboy, so will always recommend them, in any form. As the RAMs are really short, you'd likely be best served with a slider of some sort. If you get an auto-slider, be aware that B&W does not support the use of them and will void their warranty if you do use one.
Also, if you do go with the AUH, spend the money for the chains. There are states that consider it a ball hitch, no different than a bumper pull, and =require= chains. AZ is one of them. Now, actual enforcement is a different story...
Lyle
MudChucker
Niverville Manitoba
Posted: 04/01/19 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
And I've seen a full size f350 dually with a dented cab and crushed fender.
To slide or not will really depend on the trailer design... How ever to my point, I've never had to slide my hitch and I get into some tight spaces. Only caveat here is that I can tell that if my trailer tires should any more than a foot higher then the tow vehicle on a tight cut, I may have to slide or straighten out a bit.
