RV.Net Open Roads Forum: Tow Vehicles: Cummins 5.9 Filters
Search only in Tow Vehicles
 > Cummins 5.9 Filters
Page of 6
Cummins12V98
on the road
Posted: 02/11/19 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Gulfcoast wrote:
I want the best filter for sure. Thanks
What about servicing the transmission, since I just bought it?
Get someone to do a complete fluid "EXCHANGE" and adjust the inner and outer bands. Or do it your self as it's not hard to do at all.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Gulfcoast
Southeast
Posted: 02/13/19 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
Some of you guys here recommended G---'s for the filters.
Placed my order yesterday and late today got an email.... "on backorder".
Will cancel the order in the morning when they open again.
Cummins12V98
on the road
Posted: 02/13/19 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Is Geno’s a secret???
twodownzero
NM
Posted: 02/14/19 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
twodownzero wrote:
Cummins12V98 wrote:
twodownzero wrote:
Gulfcoast wrote:
My question would be that if Cummins had wanted a 5 or smaller micron filter, would they have required one by Dodge?
Cummins sold the engines to Chrysler with no warranty. Cummins had therefore no interest in what people were running.
The engine is mounted with a Cummins/FleetGuard filter right from Cummins.
Mounted to an engine sold with no warranty.
Was not disputing that! Cummins found out that a better filtration system was needed with the injectors being damaged due to needing smaller micron filtration.
This reminds me, mine could use a new filter. Ordered one on Amazon, the Baldwin.
Durb
NW
Posted: 02/14/19 11:29am Link  |  Quote  |  Print  |  Notify Moderator
You have to drop the transmission pan to access one of the adjustments for the bands, not the most pleasant of jobs. You will also need a quality low range torque wrench. Best to do this job when changing the transmission filter which is also available from Amazon.
I bought my Ram with 62k miles, it shifted kind of clunky. I dropped the pan, changed the filter and adjusted the bands. I also replaced the pan with one with a drain plug. I filled with Castrol ATF+4 (Amazon) and drove for thirty minutes, drained off 7 quarts and refilled. 100% improved shifting performance. I now splash and fill 7 quarts of ATF every other oil change. really simple.
Can't say why, but many on the forum discourage using one of the transmission flushing machines.
Cummins12V98
on the road
Posted: 02/14/19 11:59am Link  |  Quote  |  Print  |  Notify Moderator
"Can't say why, but many on the forum discourage using one of the transmission flushing machines."
TRUE, but I did not recommend "Flushing" I recommended "EXCHANGE" BIG difference.
VERY easy to do and you get virtually all the old fluid out.
1320Fastback
Vista, Ca
Posted: 02/14/19 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Amazon is where I get mine now. There is a Filter Service warehouse that strictly sells Baldwin that I pass daily during my commute but their prices are so high. I can get 3 of the Baldwin BT7349 oil filters I use on Amazon for just about the price of two that they sell. Same with the Fuel Filters.
Heck I just bought Rotella from Amazon [emoticon]
1992 D250 Cummins, 5spd, 4"' straight piped, sensors deleted, airbags, DAP injectors, 18cm.
garyp4951
TN
Posted: 02/15/19 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Glacier Diesel Power 2 micron filter installed on a 03, 5.9 Cummins, 225k miles with stock injectors.
Cummins12V98
on the road
Posted: 02/15/19 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Yep proof proper filtration works!
mapguy
Puget Sound
Posted: 02/16/19 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Diesel fuel Filtration requirements for a common rail high pressure system are much difference than the requirements for a low pressure mechanical pump system. Both systems are severely damaged by very small amounts of free water in the fuel.
High pressure systems are damaged easily by ~5-7 micron particulate. Especially if emulsified water is also present.
If you want an eye opening read - go to the Bosch website and research cp3/cp4 series pump systems in regards to fuel specifications.
Caterpillar a few years ago did some extensive studies on diesel fuel filtration needs of a high pressure common rail system. These studies are available on the internet with some searching....
On fuel filtration - you cannot get hung up on the "micron rating". It really is a meaningless number unless you have a few more facts. Like the Beta ratio of the filter. Or the nominal and absolute micron ratings.
Most don't understand that the high pressure fuel system really has two contaminate sources that take differing filter media to minimize the risk of injection system failure.
Particulate
Water
The filter in the previous post, if a FF5320, is a 5 micron @ 98.7% efficiency as tested to SAE J 1985 standard. It also does not protect against water.
* This post was edited 02/16/19 06:05pm by mapguy *
Page of 6
