RV.Net Open Roads Forum: Tech Issues: shore power problem
 > shore power problem
sledfisher
south prairie,wa
Posted: 02/10/19 12:52am Link  |  Quote  |  Print  |  Notify Moderator
I had some work done on my 94 bounder pusher.where the batteries where discounted. rear main seal ,work by cummins. to what extent I don't know if they discounted all of them or just the 1 battery.but now when I go to plug into shore power it blows the c/b.so I traced the power cord and it seems to run to the inverter under the bench seat .has any body else have a problem with their shore power. I cant find a correlation between undoing the battery vs blowing the c/b any thoughts
RoyB
King George, VA
Posted: 02/10/19 05:02am Link  |  Quote  |  Print  |  Notify Moderator
Check the hookup of the batteries. make sure the '-' Negative terminal goes to frame ground... Having these reversed will trip circuit breakers...
Roy Ken
