RV.Net Open Roads Forum: Roads and Routes: How's the mountain driving...
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > How's the mountain driving...
Terryallan
Foothills NC
Posted: 02/10/19 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
rgatijnet1 wrote:
Terryallan wrote:
goufgators wrote:
Planning to go basically NNW from Clayton, Ga. to Sweetwater, Tn.I know, according to the map, that some of that area is mountainous but was wondering if there are steep grades. I don't mind mountain driving but try to avoid long, steep climbs and descents. If you know the area, will appreciate your response and advice.
IF you are planning on running interstate highways most of the way. Be advised. Interstates have a Max grade of I believe 7%. So you should never see anything steeper on the interstate. And on those max grades they have a slow lane up, and down.
Do remember going up is much easier than coming down. Be sure to gear down, let the engine do most of the braking, EVEN if that means going all the way down to 1st, or 2nd gear. Come down slow. You will be fine.
I believe that is true of the East. Some of the Interstate Highways out West can a little steeper than that.
Actually I was wrong (looked it up) The standard max grade is 6% with 7% exceptions for mountain highways with a speedlimit of under 60 MPH. there is one in Vale, one in Texas. NC has several at 6%. From all I found, 7 is the max on interstates.
However once off the interstate, the grades get much steeper. In the west, and in the East. Some in the Blue Ridge MTs are more than 10% as are some in the Rockies. But generally those are pretty twisty, and have low speed limits
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Allworth
Orlando, FL
Posted: 02/11/19 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
If in doubt go to the Federal Highway Administration website and look up the standards for design of each class of U.S or Interstate numbered roads.
I believe you will find 6% with a 7% exception to be correct for Interstates.
I believe it is 7% with a one mile limit and then 10% for the exception on numbered U.S routes. Runaway ramps are required on 7% or greater.
NEVER use a runaway ramp except in an extreme emergency. You will end up paying for two tow trucks and a bulldozer to come dig you out.
A
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
Supercharged
Az.
Posted: 02/22/19 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
All mountains east of Mississippi River are baby hills. Come to Colo. or Utah.
So big a world, so little time to see.
doxiemom11
On our way to Michigan
Posted: 02/22/19 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
We use Mountain Directory West or East for mountain areas.
