RV.Net Open Roads Forum: Tech Issues: Changing out the shower valve
 > Changing out the shower valve
magicbus
Nantucket Island, MA
Posted: 02/10/19 10:26am Link  |  Quote  |  Print  |  Notify Moderator
My shower valve started leaking so I need to replace it. It looks like I can use a standard single handle shower pressure-balancing rough-in valve if I find one similar to the one I have to avoid hose work. Anyone replaced one with a home model?
Thanks,
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
dougrainer
Carrolton, Texas
Posted: 02/10/19 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Most of the Motorhome Shower faucets are identical to residential installs. Most of the time, if you can get the same or identical Cartridge, you just pull it out and slide the new one in. Doug
MudChucker
Niverville Manitoba
Posted: 02/10/19 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
No worries, everything in my rv's are home units, I can't see why your idea Wouldnt work.
We try to stick with Moen because the replacement cartridges are free.
2017 Cougar
2015 Ram 3500 Megacab 6.7 Cummins Aisin transmission
magicbus
Posted: 02/11/19 04:51am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the responses. I opened the wall behind the valve and now just need to clip the hose clamps and pull the valve.
Dave
