RV.Net Open Roads Forum: Travel Trailers: New Trailer traveler - light weight, single
 > New Trailer traveler - light weight, single
Terryallan
Foothills NC
Posted: 02/10/19 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
Bluecatch9 wrote:
Thanks! All advice is appreciated. I will chase the warm weather so the cold issue is not an issue.
Thanks!
Unless you stay in CGS your AC won't work UNLESS you invest in a good sized generator. Just something else to think about, and haul around
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
BarabooBob
Baraboo, WI
Posted: 02/10/19 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
I tow a 3000 pound 17' single axle trailer. When I am driving at 55 mph, I can squeak out about 12.5 mpg. At 65 mph, I get 10 mpg. I drive a Ford F150 with 3.5l EcoBoost. I actually get better gas mileage than most gassers. The diesels will get better mileage, maybe.
How much camping experience do you have? Where do you expect to stay if you don't use campgrounds? Boondocking is great if you have the experience to find and properly use the backcountry sites.
Bob & Dawn Married 30 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
All I could afford
North jersey
Posted: 02/10/19 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Definitely agree with getting a similar size used trailer and trying it out for a while before you commit to a new unit
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
colliehauler
Mc Pherson KS USA
Posted: 02/11/19 12:24am Link  |  Quote  |  Print  |  Notify Moderator
I'll agree with Grit dog and suggest you purchase a used or rent to see if this will work for you without a big expenditure. Lots of books also available on low or no cost camping. As someone else pointed out you will have no A/C without electricity. You might be able to add larger tanks if you have the room as well. Solar could keep the battery charged when boondocking without power. Good luck with whatever you decide.
Bluecatch9
34119
Posted: 02/11/19 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys. Will likely go used - unless new ends up being so close in price that it makes it a no brainer.
I will probably set up some sort of solar system as well. I am very handy and am looking forward to tinkering also.
twodownzero
NM
Posted: 02/11/19 07:50am Link  |  Quote  |  Print  |  Notify Moderator
If you're planning on boondocking, a slightly larger trailer will probably offer larger holding tanks. The frontal area of the trailer is the biggest killer of fuel mileage. Weight matters some, but pulling a brick through the air takes some fuel no matter what.
near La Cuesta Encantada
Posted: 02/11/19 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
“I will probably set up some sort of solar system as well.”
Some sort of solar system starts with an energy survey. The survey determines the needed batteries, panels and controller.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
colliehauler
Mc Pherson KS USA
Posted: 02/12/19 03:20am Link  |  Quote  |  Print  |  Notify Moderator
You won't be disappointed if you like tinkering, unfortunately RV'S are high maintenance items. Water intrusion is the biggest killer of a RV. Buying used throughly check out for indicators of water damage.
myredracer
Langley B.C.
Posted: 02/12/19 09:26am Link  |  Quote  |  Print  |  Notify Moderator
I like the looks of the R-pods. They look more aerodynamic too. No idea if they're any good or not. They are in the 18-20' range and have 30 gal. black & grey tanks which isn't bad at all. By comparison, our 29' TT has a 32 gal. black tank which lasts the 2 of us up to a week.
When it comes to black tanks, the key to making them last longer between dumps is lots of water - add 2-3 gallons before each use, don't skimp on water when flushing, fill to full or near full before dumping and then rinse thoroughly.
Filling up the grey tank from showering won't be the problem, it will be washing dishes and food prep. in the kitchen sink. Disposable plates & cutlery can help. We sometimes use a folding wash pan for rinsing and then toss the (clean) water outside, depending on the CG. Same when draining some boiled vegetables. One of those marble-coated frying pans are good because you can just wipe them clean with a paper towel.
Sanidumps.com lists available dump stations around the US.
If planning to spend a lot of time in a TT, I'd want a model with a sofa and hopefully a sofa that is comfortable (many are not). Sitting upright on a dinette seat for extended periods can be tiring after a while.
I hate CAPTCHA. CAPTCHA sux. CAPTCHA is evil. CAPTCHA needs fixing.
Gil, Deb & Dougal the Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH
2009 F250 super duty, V10, 8' bed, Hawkshead TPMS
Durb
NW
Posted: 02/12/19 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Bluecatch9 wrote:
Thoughts? The decor scares me - but it could also show pride of ownership......what do you veterans think?
https://www.rvtrader.com/listing/2007-Cikira-Rv-Classic-Cruiser-16LB-5006272270
It shows areas of exterior skin delamination which generally means a leak and possibly other damage. The good news is you can save money on a trailer lock. I like your plan, if it were me, and I was going to travel extensively, I would want tandem axles for towing comfort. Maybe bump your size range up a little. I hope you are a small guy, navigating that bathroom would be a challenge for me. Good luck.
