RV.Net Open Roads Forum: Travel Trailers: Outdoor Shower Door Jammed
 > Outdoor Shower Door Jammed
jjjandrbaker
San Antonio, TX
Posted: 02/10/19 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Tried to open the outdoor shower door last week when camping, but the key won't turn at all. I'm assuming that the shower head is in the way of the lock mechanism or something like that. I didn't want to force it, because, if the key broke, I wouldn't have been able to open up my storage compartments. I haven't opened it since I winterized earlier. Anyway, if you have experienced this, what did you do to solve the problem?
Jim Baker
San Antonio, TX
travel blog and photos
ScottG
Bothell Wa.
Posted: 02/10/19 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Can you get to the back side of it in some cabinet? You could jiggle the hose and perhaps manipulate it out of the way.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Boon Docker
Posted: 02/10/19 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Try pushing on the door beside the lock while turning the key.
Johno02
Lexington, TN USA
Posted: 02/10/19 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Sure you have the right key?? When you put the key in, will it rotate the cylinder at all??
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and a grouchy, old, tiny dog
ScottG
Bothell Wa.
Posted: 02/10/19 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
I've always replaced the locks with 1/4 turn levers.
Anyone who needs a shower that they're willing to steal it is welcome to it. [emoticon]
jjjandrbaker
San Antonio, TX
Posted: 02/10/19 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
I'll have to check on that. There might be access from under the bathroom sink. Thanks for the suggestion.
jjjandrbaker
San Antonio, TX
Posted: 02/10/19 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
Tried that. Also tried pulling the door forward a bit with a screwdriver. Neither worked.
jjjandrbaker
San Antonio, TX
Posted: 02/10/19 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
It is definitely the right key. It goes in but will not turn at all.
wnjj
Cornelius, Oregon
Posted: 02/10/19 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a stuck tumbler. Something jamming it from the inside would probably allow some movement. Try inserting the key then tapping firmly on the cylinder while pulling the key in and out or turning.
Rangerider
No Va
Posted: 02/10/19 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
If it's a CH 751, try a different one. I had one that would open the shower door and one that seldom opened it!
