RV.Net Open Roads Forum: Class A Motorhomes: Where in Tallahassee area...
 > Where in Tallahassee area...
goufgators
Crawfordville, Florida
Posted: 02/11/19 05:11am Link  |  Quote  |  Print  |  Notify Moderator
Is there a alignment shop in the Tallahassee area that will agree to change the 'spec' caster setting to one of 5 to 6 degrees positive? The shop I normally use for alignments is hesitant to set at anything other than factory spec.
2017 Winnebago Sunstar (gas)
2005 Honda CRV Toad
Invisi-brake
apr67
Tallahassee, Florida
Posted: 02/11/19 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Check out the places listed in replies to my intro on the Thor forum.
http://www.thorforums.com/forums/f3/hi-tallahassee-15982.html
2014 Chevy Express 3500
2016 Jayco White Hawk 32DSBH
Gone-2013 Keystone Bullet 294BHS
Gone-2007 National SurfSide 34DE
Gone-2006 ForestRiver Sunseeker 2900LTD
Gone-1994 Fleetwood PaceArrow
Gone-1978 Kit RoadRanger
ArchHoagland
Clovis, CA, USA
Posted: 02/11/19 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
I'm curious why you want to do that.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Bikeboy57
Inverness, FL
Posted: 02/11/19 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
More caster makes it track better, less wandering. No free lunch though, too much caster can make the wheels shimmy like a shopping cart.
3 to 4 is about standard. I would be awfully cautious about going to 6.
Call josams in orlando
Richard and Rhonda
1999 Newell
Subaru Outback toad
Fla Tom
Crawfordville Fla
Posted: 02/11/19 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Have you talked with Sermons alignment (off west tenn st )? They are great at alignments.fyi we also live in crawfordville.
goufgators
Posted: 02/12/19 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Thanks! I did talk to them this a.m. and will be taking the MH to them Friday. He is very familiar with the steering wandering and knowledgeable about the movement of caster more to positive.
Just wondering, do you have a MH and, if so, have you experienced the steering problem? This our 4th and each has had this same problem.
apr67
Posted: 02/12/19 11:27am Link  |  Quote  |  Print  |  Notify Moderator
Caster is how the steering axis is tilted, forward/back.
Think about the front wheels on a working shopping cart (not the one at walmart that wobbles and drives you nuts). The point where the wheel pivots is behind where the center of the wheel is. Very stable, it just wants to go straight.
A really good explanation of all alignment terms. https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=4
Fla Tom
Crawfordville Fla
Posted: 02/12/19 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
we do have a motorhome (also on our 4th also) luckily this coach has not had any steering issues.
