RV.Net Open Roads Forum: Tech Issues: Blown Frige Fuse - In A Bind!
 > Blown Frige Fuse - In A Bind!
Dave H M
IL
Posted: 02/11/19 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
I just happen to be at the stick house with the fifth wheel plugged into the garage. only thing I had running was the frige. All appeared well two days ago. Went out just now and frige was off. Discovered the 15 amp DC fuse blown. New one blows immediately. Furnace apparently runs on the same circuit - it is dead also but had not been running.
So what do you think. We were supposed to leave for the East coast early on Wed. No mobile techs round here. [emoticon]
Thanks
BFL13
Victoria, BC
Posted: 02/11/19 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
First thing IMO is get a handful off 15 amp fuses, disconnect the 12v at the back of the fridge and try it with the furnace to see if it works. You want to know if it just the fridge or just the furnace with the short. Or anything else on that circuit--test that separately.
Once narrowed down, depends what to do next.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
dom101
kelowna BC
Posted: 02/11/19 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
You didn't mention if its a rv fridge or house type. Also if its a rv fridge you could try running it on propane only
sempka
Oklahoma
Posted: 02/11/19 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
12 volt DC is needed for the rv fridge to run on propane.
2000 Holiday Rambler Admiral
Dave H M
IL
Posted: 02/11/19 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
It is a Dometic RV Frige. When this problem cropped up it was plugged into shore power and running on gas because i had set it for gas.
Sorry about the lack of info.
I am going to do BLF's suggestion and be back on later this eve. live in the sticks and have to take a ride to the city.
Follow UP: [emoticon] So I undid some wires in the back of the frige - Yeah bull in a chin shop. I disconnected the three that had a wire nut - wrong. Found the 12V power supply and disconnected it. Stuck a fuse in and it showed 12V at the back of the frige and the heater worked. So, I thought here we go and plugged the 12V power back into the terminal on the back of the frige and the fire works did not go off. What the hey. hooked all back together, went inside and hit the on button and the frige indicted it was happy.
What do you folks think. Should i throw something at it for the hey of it?
thanks again.
* This post was edited 02/11/19 03:36pm by Dave H M *
Dave H M
IL
Posted: 02/11/19 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
bump
BFL13
Victoria, BC
Posted: 02/11/19 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
The fridge needs to be left on for a time before declaring victory. In the OP it ran at first but later it was found with the blown fuse.
Is part of the story missing? Perhaps doing something with the house batteries in preparation for the trip?
Dave H M
IL
Posted: 02/11/19 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
House batt been in there for three months without me touching it.
Nothing out of the ordinary. [emoticon]
If she pops in a day or two it won't surprise me. We will see, but I thought maybe someone who has been down this road might chime in.
Dusty R
Charlotte Michigan 48813
Posted: 02/11/19 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
Google your make, model, & year of your fifth wheel and see if you can pull up a wiring diagram. Then see what all is on the same circuit.
Dusty
Chris Bryant
Arden, North Carolina
Posted: 02/12/19 04:36am Link  |  Quote  |  Print  |  Notify Moderator
It’s not likely to be the fridge, as it has a 3 amp fuse first thing on the board, unless it is a short in the harness between terminals and board (the safety stuff).
-- Chris Bryant
My RV Service Blog
The RV.net Blog
