RV.Net Open Roads Forum: ? Solution for Mud Daubers In/On A/C?
 > ? Solution for Mud Daubers In/On A/C?
dcmac214
SW OKLA
Posted: 02/11/19 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a solution to keep mud daubers out of air conditioning units when the RV is being used? You can cover them up when in storage but what about at the lake or wherever? Checked with the local dealership and they don't know of a solution (other than keeping the A/C covered up tight).
mobeewan
Hampton, Va
Posted: 02/11/19 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
You can make your own screens out of hardware cloth similar to the ones for the furnaces and the water heater. Just make sure that they are pan shaped so they give more surface area for air to flow through that you will lose with screen wire. That's why the ones for the water heater and the furnace arer pan shaped so that you don't restrict are flow.
Chris Bryant
Arden, North Carolina
Posted: 02/11/19 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Moth balls, livestock ear tags.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
JimBollman
Lost State of Franklin
Posted: 02/11/19 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
I bought some Hot Shot No-Pest Strip to try this year. I plan to put two strips in the housing. They work to keep paper wasps out of my shed so thought it was worth a try.
cpaulsen
Oregon
Posted: 02/12/19 03:23am Link  |  Quote  |  Print  |  Notify Moderator
Used fiberglass insect screen on mine. Took the cover off...…..cut the screen to fit inside and a few dabs of silicone to hold it in place.
cpaulsen
georgelesley
Tennessee
Posted: 02/13/19 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Got a tip here once to use a cat flea collar in the refrigerator outside compartment. Works wonderfully. Should also work in the a/c unit. I change it twice a year.
George & Lesley
2014 Itasca Sunova 33C, 2019 Jeep Cherokee Lattitude Plus toad, Demco/SMI towing system
