RV.Net Open Roads Forum: Tech Issues: furnace leak
 > furnace leak
oldgrey
alberta
Posted: 02/11/19 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
hoping someone could help me out here. so I basically live in my rv up in alberta Canada, -25c usually in the winter...just as of late when my furnace kicks in I get a strong exhaust smell inside the unit and it seems the exhaust isn't blowing out with much force anymore. any ideas as to why this is happening??? after a min or 2 the leak seems to stop and all is fine.
SoundGuy
S Ontario
Posted: 02/11/19 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
Can't help you with your specific problem but I sure wouldn't be using the furnace AT ALL if there was any hint at all that it could be leaking killer CO into the trailer, regardless of how cold it may be outside.
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
mchero
Henniker, NH
Posted: 02/11/19 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Make/Model of your RV?
You smelling exhaust you need to stop using it now.
Sounds to me like its rusted thru the heat exchanger.
Need to have it pulled out and throughly inspected.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
midnightsadie
ohio
Posted: 02/11/19 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
x2 this is a killer ,call a mobil tech if your not sure of working on it. or maybe its time to be replaced?
Monterey, CA
Posted: 02/11/19 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Time for a pro inspection and repair.
time2roll
Posted: 02/11/19 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
First check you CO detector is working and has fresh batteries.
Furnace probably needs to come out for disassembly and inspection. My guess you have some type of animal or nest in or on the firebox, cracked fire box or misaligned or faulty exhaust port.
Restricted vent may also cause overheating of the fire box.
675w Solar pictures back up
PastorCharlie
NC
Posted: 02/11/19 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Dirt Dabbers and wasps often build in the outside vent in warm season when furnace is not used. Over time it accumulates and restricts the venting when in use.
oldgrey
alberta
Posted: 02/11/19 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
HEY THX ALL, took it all apart and theres a hole in the piping thats where the leak is from..gonna take it to a welder and see if its fixable, thx for all the replys
All I could afford
North jersey
Posted: 02/11/19 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
And check that u have a functioning carbon monoxide detector
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
Dusty R
Charlotte Michigan 48813
Posted: 02/12/19 06:26am Link  |  Quote  |  Print  |  Notify Moderator
You say hole in the piping, if that is part of the heat exchanger then DO NOT try to weld it, it must be replaced.
 > furnace leak
