RV.Net Open Roads Forum: Class A Motorhomes: PD 52 transfer switch hum normal?
Open Roads Forum  >  Class A Motorhomes  >  Travels & Favorite Places
 > PD 52 transfer switch hum normal?
MarkieBob
Burlington, WA
Posted: 02/14/19 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
My pd52 hums pretty loud. How loud is too loud? Wrap in insulation?
2011 Holiday Rambler Vacationer Class A
2004 Suzuki Grand Vitara toad.
2006 Ford F350 PSD 6.0 4x4
1990 18' Seaswirl boat
enblethen
Moses Lake, WA
Posted: 02/14/19 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Check for loose connections.
Think about replacement as it will fail when you need it the most.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MarkieBob
Burlington, WA
Posted: 02/14/19 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
I tightened connections. No change
Is there a better model available?
garyemunson
Reno, Nevada
Posted: 02/14/19 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
They buzz when the relays get dirt inside and the two parts of the armature cannot "seal up" tight. Once you are home and have time, dismantle the relay and clean it out. If necessary, sand the mating surfaces against a sheet of fine sandpaper on a flat surface. With alternating current relays, if the two metal surfaces cannot solidly connect with each other in addition to buzzing it also can make the relay coil run hot and eventually fail. You can also buy new relays fairly inexpensively to replace it once you get it out and can identify it. eBay is your friend. If you buy a completely new transfer switch, get the PD52DCS model as they utilize internal rectifiers to furnish DC (direct current) to a DC coil relay that will not buzz when it gets dirt in it and will not burn out from not "sealing up" properly like is very necessary with an AC coil. A hazard of using AC coils in an RV that gets exposed to a lot of dirt and dust.
time2roll
Posted: 02/14/19 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
I recommend a new transfer switch.
http://www.bestconverter.com/50-Amp-Transfer-Switches_c_183.html
675w Solar pictures back up
MarkieBob
Burlington, WA
Posted: 02/14/19 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
Will this pd52dcs be a direct bolt on replacement for mine?
garyemunson
Reno, Nevada
Posted: 02/15/19 02:28am Link  |  Quote  |  Print  |  Notify Moderator
I understand they are. The DC conversion is all internal. You might want to go to their website and submit a question. I've had to clean relays about every 3 years on our last 2 RVs. After a while you get good at it. It's dusty here out West.
Wherever I happen to park
Posted: 02/15/19 07:11am Link  |  Quote  |  Print  |  Notify Moderator
How old are they... If you happen to have cause to be in centeral south lower Michigan (Marshall) they may be able to fix it for you if they are new enough or for a slight fee.
I have a PD 9180 converter that died.. Walked into the plant (off Old US_27 on industral) and the gal ask "Can I help you" I pointed to the box and said "DEAD" she sent me through a pair of double doors wehere we did the Can I help you thing again she said on my desk.. 238 dollars later I walked out with a brand new Factory Refurb and on the road again.
Home is where I park it.
crawford
Dandridge Tenn.
Posted: 02/15/19 10:12am Link  |  Quote  |  Print  |  Notify Moderator
mine always did till I sold is 15 years later
Change from a c class to a A class Georgetown 07 triple slide
MarkieBob
Burlington, WA
Posted: 02/19/19 11:15am Link  |  Quote  |  Print  |  Notify Moderator
UPDATE: Thank you for your responses. I bought and am having installed the new PD52DCS at camping world next week. Note: They had a sale on the unit, plus $25 off on President's day, plus $59 this month to install anything. Seemingly a good deal.
