RV.Net Open Roads Forum: Class A Motorhomes: PD 52 transfer switch hum normal?
Open Roads Forum  >  Class A Motorhomes  >  Travels & Favorite Places
 > PD 52 transfer switch hum normal?
MarkieBob
Burlington, WA
Posted: 02/19/19 11:17am Link  |  Quote  |  Print  |  Notify Moderator
garyemunson wrote:
I understand they are. The DC conversion is all internal. You might want to go to their website and submit a question. I've had to clean relays about every 3 years on our last 2 RVs. After a while you get good at it. It's dusty here out West.
Thanks Gary. I did call PD and he said the DCS will transfer over easily. Main difference is the size of the box.
2011 Holiday Rambler Vacationer Class A
2004 Suzuki Grand Vitara toad.
2006 Ford F350 PSD 6.0 4x4
1990 18' Seaswirl boat
MarkieBob
Burlington, WA
Posted: 03/04/19 10:33am Link  |  Quote  |  Print  |  Notify Moderator
UPDATE: MH is sitting at camping world now getting the transfer switch installed. I'll let you know how it works[emoticon]
MarkieBob
Burlington, WA
Posted: 03/05/19 09:36am Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]New pd52dcs does hum also but half as loud. CW installed wrong. I can’t get my electric cord out
crawford
Dandridge Tenn.
Posted: 03/05/19 10:30am Link  |  Quote  |  Print  |  Notify Moderator
they all hum your new one is newer so hum is lower and because they put more sound board around it you older one did not. I guess spending the money make you more secure great happy camping.
Change from a c class to a A class Georgetown 07 triple slide
tropical36
Southwest Florida_USA
Posted: 03/06/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
MarkieBob wrote:
enblethen wrote:
Check for loose connections.
Think about replacement as it will fail when you need it the most.
I tightened connections. No change
Is there a better model available?
Tightening wire connections, only insures a good connection that won't get hot and cause crystallization of the wires and other current delivery problems.
Pull the relay contactors themselves and use emery cloth and a small file for cleaning the contacts and where the coils make contact, as well.
Had to believe they're all making noise or that they all are bad.
Check the little springs on the arms, while you're at it.
You can always replace one with a like model, if really faulty.
With re-reading the thread, it seems that the deed has been done, so you might as well ask for the old one back for having a looksee and for having a spare, if needed.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
MarkieBob
Burlington, WA
Posted: 03/08/19 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
CW corrected the issue. A technician with 20 years experience fixed it. It does hum but tolerable—unlike the pd52. So we’ll see how it goes.....
MarkieBob
Burlington, WA
Posted: 03/19/19 10:09am Link  |  Quote  |  Print  |  Notify Moderator
A constant low volume hum. We'll see how it goes over time
MarkieBob
Burlington, WA
Posted: 03/19/19 10:10am Link  |  Quote  |  Print  |  Notify Moderator
MarkieBob
Burlington, WA
Posted: 03/26/19 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
3/19 update: my batteries failed to keep a full charge with the old transfer switch. Of the four lights on the panel it always dropped to three quickly then two and finally one light. NOW with the new transfer switch it’s not only quieter but the four status lights stay on—day after day! Not sure why. In both cases the mh was unused. Perhaps the old transfer switch drew power out of the batteries just sitting?
MarkieBob
Burlington, WA
Posted: 04/18/19 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
4/17 second update. My pd52dcs transfer switch is noisy! They will send a new one. CW EMPLOYEE Thought it was my power source at home! Can that be true?
