RV.Net Open Roads Forum: Water ingestion in engine on 2011 Tiffin Phaeton 36QSH
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Water ingestion in engine on 2011 Tiffin Phaeton 36QSH
6string
Springfield, Illinois
Posted: 02/15/19 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
At 50,000 miles I got a crankcase pressure high code. After changing many filters they had to pull the head off my Cummins engine. Cylinders glazed and signs of water ingestion. Had a complete overhaul. I proved they were right by pulling air intake hose off filter and putting a bag over the hose. One good day of rain and I had maybe a quart of water in the bag that would have been in the air filter. Has anyone had this problem. Trying to find out if this was a common problem. Thank you
lryrob9301
Mid-Atlantic
Posted: 02/15/19 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
You need to check your air filter, it should have a drain hole in the bottom to remove any water that comes in the air pipe.
2013 Tiffin Phaeton 40QBH
2016 Chevrolet Equinox LTZ AWD V6
DSDP Don
Moorpark, Ca
Posted: 02/15/19 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Your coach has the air intake at the upper left (driver's side) corner of the rear cap. There is a large diameter tube that runs down the inside wall of the rear cap, turns and goes into the air cleaner. Typically, at the bend in the tube as it turns toward the engine is a drain. Many have a "duck valve" type rubber drain. Looks like two large rubber lips hanging down. It's suppose to drain and water coming in through the air intake. Check your coach for that drain valve.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2016 GMC Canyon 4WD Crew Cab
Big Katuna
Deland, FL
Posted: 02/15/19 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
They are used in the storage bays, too. They often weld together.
My Kharma ran over my Dogma.
Wherever I happen to park
Posted: 02/16/19 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Something occurred to me. Since I'm not Diesel certified or expierenced I can not comment directly on this issue.. but...
You speak of water ingestion and the "Tone" indicates this is damaging to the engine (not arguing or questioning that. Believe it to be fact).
I recall not long ago reading about "Water vapor injection" systems that basically sprayed water into the air intake to improve MPG/Performance.
The ads kept hitting my Snake Oil filter as.. Well... Back to the original post for an explanation of why I was leary of them. .I suspected just what the OP typed.
Some body builders do a great job some not so good. Many Workhorse (Gassers) the body builder builds it so they suck water when it rains.. NO EVIDENCE mine does. but.... Well.. I may have just not seen it
Home is where I park it.
TCollins
NW Ohio
Posted: 02/16/19 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
There is a difference between water vapor injection and ingestion of a large slug of water.
Guys who build up their diesels use water vapor injection to increase power and assist in cooling the combustion chamber. Sometimes they will add something like alcohol to the water to increase power. Pullers (farm tractors) will inject gallons of water in a pull to keep things cooler.
Dale.Traveling
Newport News, VA
Posted: 02/17/19 05:33am Link  |  Quote  |  Print  |  Notify Moderator
Short term metered water vapor injection can be used for a quick power boost but the engine needs to be properly configured. A modern computer controlled engine the gain might marginal or even result in a loss of engine power without reprogramming. Many fighters and heavy bombers during WW2 used water injection for short term boosts during take off with a heavy load or during dog fights.
Un-meter rain water ingestion into a modern day diesel engine? I suspect it is something best avoided. I'm a bit surprised that who ever rebuilt the engine didn't go thru the intake and such searching for a cause of the water such as a clogged drain.
2006 Hurricane 31D built on a 2006 Ford F53
wolfe10
Posted: 02/17/19 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Two most likely cause of engine failure are:
Large enough quantity to cause hydrolock bends rod(s) and/or break piston(s).
Water soak air filter so it fails and allows dirt to enter engine. This is known as "dusting".
Was the oil milky?
Please let us know which of these or other damage was incurred. Have never heard of enough water ingestion that it would cause cylinder wall glazing and excessive blow-by.
But, depending on engine (parent bore or linered) glazed cylinders (if this the only damage) should not require a "complete" overhaul.
* This post was edited 02/22/19 10:46am by wolfe10 *
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
6string
Posted: 02/21/19 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Back to original post. How about you Tiffin Phaeton owners? Any water injestion problems with your engine?
wolfe10
Posted: 02/21/19 08:10am Link  |  Quote  |  Print  |  Notify Moderator
Can you enlighten us on exactly what engine damage was caused by the water (see my post above).
That could be a help to others.
Thanks.
