RV.Net Open Roads Forum: ISX 600 HP Cummins engine pros or cons
 > ISX 600 HP Cummins engine pros or cons
daveb1256
Nebraska
Posted: 02/16/19 11:50am Link  |  Quote  |  Print  |  Notify Moderator
We are considering purchase of a 2006 Monaco that has the Cummins 600 HP ISX engine. Has anyone had experience with this engine, maintenance issues, recalls or any pros or cons. This engine currently has 1050 hours or 38K miles on it, appears to be very clean with no leaks or other observable problems.
Johnny G1
Clearwater, British Columbia ,Canada
Posted: 02/16/19 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Its in just about every truck on the road that is pulling heavy loads, so can't be much wrong with it.Definately not needed in a 50,000 lb mh.
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 28' 5th wheel Travel Aire. Lots of fun.
2oldman
New Mexico
Posted: 02/16/19 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
2003 Monaco with ISX post
Ivylog
Blairsville, GA and WPB, FL.
Posted: 02/16/19 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
The good news is it’s not a 2007 or later ISX...I made sure my 08 Navigator had a 2006 engine, BUT I was not aware of the following problem. On another forum there is a lot more info on the ISX dropping the #6 intake valve to the tune of $30K in repairs. No good reason why and it’s more with the 600/650HP engines and 07 and later. More info here: ISX #6 valve breaking Some think it’s the gasses from the EGR that weakens the stem of the valve but why is it only #6 and mainly in MHs and not often in trucks?
My ISX is a 525 HP with 47K miles and I may drill a hole opposite the #6 in the intake manifold to look at the stem of that valve. If it is pitted (hopefully not) there are new valves and seats for the ISX but you are still looking at $20K+ to install.
I had to have a 08 MH because of a 10 year rule where we snowbird and Monaco did not make any 08s with the Detroit 60 engine. I would only buy a big Monaco with a Detroit 515 HP engine. Too many expensive unknowns with a ISX, especially the higher HP engines.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
Tom/Barb
Oak Harbor, Wa
Posted: 02/16/19 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, but it is sure nice to be able to pull out and go around up hill traffic any time you choose.
ISX cummins dependable as it gets. and probably just passed its second oil and filter change.
Ivylog
Posted: 02/16/19 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Run unless you can buy the 2006 Signature with a ISX 600 for less than $100K. A 06 Sig with a Detroit for $130K, yes. I paid $165K for my 08 Navigator a year ago.
hypoxia
Arizona
Posted: 02/17/19 05:50am Link  |  Quote  |  Print  |  Notify Moderator
My 2007 Coach with a 2006 ISX, EGR but not DPF, has 83,000 miles and running strong.
Who knows what lurks inside any engine. There have been some valve corrosion problems reported. I'm waiting for Lvylog to drill and report.
Some are working the purchase deal to allow them to replace the head pre-emptively sharing the cost with the seller.
Jim
2007 Monaco Signature Noble III ISX 600HP
Ivylog
Posted: 02/17/19 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
Well, like so many things in life, there is not your normal intake manifold on the ISX. The air disappears into the side of the dohc head in the middle...doubt you could get a camera to make two 180 degree turns. Maybe there is a camera that looks sideways on a flexible rod as size would be less of a problem coming in the 4” diameter hole on the side of the head.
*I see you can buy a $25 lighted borescope with a mirror on the end.
* This post was edited 02/17/19 12:45pm by Ivylog *
JaxDad
Greater Toronto Area
Posted: 02/17/19 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
My only question with that engine would be the hours, especially when it was new’ish.
If you do the math 38k miles over 1050 hours means the average travel speed of its whole life is a whopping 36 mph.
I don’t know of too many DP MH’s used as daily commuters / grocery getters. They run the highway for hour upon hour until they reach the destination.
For a unit like that the only explanation for an average speed that low is that it spent a LOT of time idling.
Mr.Mark
Out West and Mid South
Posted: 02/17/19 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Ivylog, I follow that thread on the other website you were referring to. Why don't you get an oil analysis to see if that can give you some info. That's how the guy that is needing is 2nd repair found out that it's happening again.
I sure hope that you never have to worry with that repair.
Safe travels,
MM.
Mr.Mark
2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo w/1,750 lb. ft. of torque, 1.5 baths, 4 slides.
2017 Lincoln MKX AWD V6 335 hp twin turbo.
