RV.Net Open Roads Forum: Travel Trailers: drain pipe to protect awning
 > drain pipe to protect awning
The ugly duckling
Central New York
Posted: 02/25/19 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
Did the 4" Eternabond thing. Quick easy and has held up well. Also that was my most deteriorated part of the awning, so it helped stabilizing things and sealing up some thread bear areas.
TheBeans
Bonney Lake, WA
Posted: 02/28/19 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone have photos to share of what this looks like?
Wendy & Darrell (aka: The Beans)
Buddy & Charlie (our camping dogs)
2014 Cougar Half-Ton 21RBSWE Travel Trailer
Camper G
Pennsylvania
Posted: 03/02/19 04:35am Link  |  Quote  |  Print  |  Notify Moderator
Yep also used eternabond on mine but that was because mine was in bad shape where the roll is exposed when stored. That was 4 yrs ago at least and its still well adhered and has allowed me to get several more years out of the awning.
2017 Dodge Ram 2500 HD, 4x4, CCSB, 6.4L HEMI, Snow Chief, tow package.,1989 Skyline Layton model 75-2251.
Vulcanmars
Naples, FL
Posted: 03/02/19 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
Not my camper, but similar photos found online.
Mars
04 V10 F250 SDCC 4X4
2016 Wildwood 32BHDS
profdant139
Posted: 03/02/19 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Great tip about using a heat gun to put a little crimp in -- thanks, Double Haul!!
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
mosseater
Dillsburg, PA
Posted: 03/04/19 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
I use two half round "D" profile gutter sections. I place the upper edge into the gutter. The two sections overlap in the center. I cut two, 1" wide slices off of 4" pvc and took about 1/3 of the round section away so they slip over the gutter and awning roll and act like clips to hold it on. Make sure you trim and smooth all sharp edges on the pieces so you don't cut the fabric. I only use it for winter storage, not travel, but it might actually hold on. It's pretty secure.
Sunset Creek 298 BH
