RV.Net Open Roads Forum: Tech Issues: Electrical issue
 > Electrical issue
gtschulz
Southgate, MI
Posted: 02/21/19 10:56am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2007 Damon Tuscany 4072. I am losing electrical power often, AC will go off, carryout satellite goes off, convection over clock blinks until reset. In other words everything on shore power goes out. However within 5 seconds the power comes back on.
Today i replaced the IOTA ATS and i still have the problem. No circuit breakers trip. I had the electrical pedestal checked all looks good there.
Any ideas of a cause?
Thank you!!!
Deputy Chief/Fire Marshal (retired)
newman fulltimer
louisiana
Posted: 02/21/19 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Tighten all wires in your breaker box your power managmant is seeing extra resistance and shutting off then resetting
gtschulz
Southgate, MI
Posted: 02/21/19 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for responding. I will do as you suggest.
1492
Arlington, VA
Posted: 02/24/19 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Posting Help and Support
MrWizard
Traveling
Posted: 02/24/19 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
would these items be on circuits that are also supplied by an inverter
if so do a power reset on the inverter, and check the battery cables and wiring of the inverter
Radiate The Happy
1997 F53 Bounder 36s
time2roll
Posted: 02/24/19 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
I would measure and start monitoring voltage on the main breakers.
Going to be a tough call on where the issue is for just 5 seconds.
Do you have an energy management system that might be shutting down power for low voltage?
I assume you have checked house battery voltage is pretty steady at ~13.5 volts.
675w Solar pictures back up
jjrbus
FT Myers FL
Posted: 02/25/19 04:48am Link  |  Quote  |  Print  |  Notify Moderator
Often overlooked is the shore power pedestal, can be loose or bad connections in it, including bad connection between breaker and buss. Circuit breakers in pedestal are often used as off and on switches, they are not switches, they are circuit breakers and can go bad.
I cringe when I have an intermittent problem, give me a total failure anyday : )
Wherever I happen to park
Posted: 02/25/19 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Also check inlet (the place you plug in teh shore cord) outlet (on the rv end of shore cord and any other screws in teh electrical chain.
I'm fond of saying many RVers have a few screws loose.. One of the circuit breakers in my Damon.. 3 1/2 full turns to tighten.. ANd yes. the device it powered worked much better after tightening.
Home is where I park it.
gtschulz
Southgate, MI
Posted: 04/14/19 08:01am Link  |  Quote  |  Print  |  Notify Moderator
Here is an update on my electrical issue. The power company checked their equipment from pole to the meter and all was well. That left either the pedestal or my motorhome. After the motorhome was rule out the park management decided to change the breaker that isolated the pedestal. It was an old breaker. After the breaker was replaced the problem stopped. I was not aware that a breaker could cause this type of problem but apparently it can.
time2roll
Posted: 04/14/19 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the follow up.
 > Electrical issue
