RV.Net Open Roads Forum: Snowbirds: Storing rv in desert heat
Search only in Snowbirds
Open Roads Forum  >  Snowbirds
 > Storing rv in desert heat
AnnieCobey
Desert Hot Springs
Posted: 02/21/19 11:28am Link  |  Quote  |  Print  |  Notify Moderator
I’m leaving my fifth wheel set up in an rv park for the summer months Any tips on what I should do to before I leave. I won’t be returning until late fall. Also can I leave food or drinks in the rv or should I get rid of them. Any advice would be great as this is my first year doing this
ItsyRV
Desert SW
Posted: 02/21/19 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Will it be have a sun protective cover over it or exposed naked to the elements?
In parts of AZ, interior temps with no a/c can easily reach over 125 degrees inside during the summer. You need a cover or at least window sunshields. I have seen sunbirds come back in fall to exploded containers of food everywhere. It's not just how hot it may get but how long that sustained heat is present. Each year all the news stations do their annual fry and egg on the hood or place a block of ice inside a vehicle to show how fast temperatures rise. One did an RV and the temps were over 125 from about 9 in the morning to 9 at night. I don't care how well an RV is built, that is some serious high temps to endure almost every day for three months. Imagine whats happening to any food or drink!
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
2oldman
Ca
Posted: 02/21/19 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Remove batteries.
OkieGene
oklahoma city
Posted: 02/21/19 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Can you store it in a place with a covered roof? Personally that's what I'd do.
The sun will just flat out detiorate your RV.
bobsallyh
Livingston, TX.
Posted: 02/21/19 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
This is done thousands of times over in the Yuma area. Drain water heater, open black and gray tanks, pour wind shied washer fluid down kitchen sink, vanity sink, and pottie (some use vegetable oil). Then cover those drains with Saran Wrap and stretch Saran Wrap across pottie below the seat. Top off batteries and disconnect. Turn propane off. Place plastic buckets full of water in bedroom, bath, kitchen, and living area. DO NOT use milk jugs. Take anything with elastic in it with you. Put silver bubble paper in the vent squares inside. Silver bubble paper all windows (between glass and blind). Some put plastic sheets over chairs etc. You can build small boxes to cover roof vents up on the roof. Also, you can build a larger box to cover AC unit. Be sure to put a patio block on each box cover. Put silver bubble paper on inside of refer vent door. Let refer doors open. You can take plastic spouting and cover your roll-up awning. cover tires and put weight against the covers. You will be surprised how good it will be inside when returning.
If I can be of more help just PM me. We do several for our friends after they leave.
pawatt
Brainerd MN / Palmview TX
Posted: 02/21/19 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for this helpful post.
samsontdog
Oregon, Wash Coast summer, Yuma Az winter
Posted: 02/21/19 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder why you don't use gallon milk containers. I put 7 or 8 in all my 13 rentals. I have been using them for 19 years. I make sure they are only 3 or 4 months old. Otherwise, I do everything else as you do
samsontdog">">
azdryheat
Tucson, AZ
Posted: 02/21/19 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
I can speak for my trailer left in the AZ summer sun for over 4 years. The graphics on the front cap fried. The so-called leather upholstery in the living room started separating from the backing material. RV's do not like the summer heat. I had it covered but the winds tore the cover to shreds. Make that two covers.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
Dick_B
Palos Heights, IL USA
Posted: 02/21/19 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Sunshield tarp with silver side up.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
joshuajim
Mojave Desert
Posted: 02/21/19 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
I live in the Mojave at 3500 MSL, not the coolest place in summer and the solar intensity is high at this elevation. I’ve stored my trailers uncovered for the last 23 years with no special preparation. Other than some fading of decals nothing damaging has happened.
I’m seeing a lot of solutions in search of a problem.
RVing since 1995.
