RV.Net Open Roads Forum: Tow Vehicles: Diesel Oil.....
Search only in Tow Vehicles
 > Diesel Oil.....
azdryheat
Tucson, AZ
Posted: 02/23/19 09:41am Link  |  Quote  |  Print  |  Notify Moderator
All diesel approved oils will work in your diesel engine. They're all the same.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
Old-Biscuit
Verde Valley
Posted: 02/23/19 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Been using Rotella Dino 15W-40 since day one in my 2007 5.9L CTD
I get oil/filter change at Dodge Dealer for $59.99 (12 qts/filter) while I swab stories, eat donuts, drink coffee in the lounge.
ksss
Eastern Idaho
Posted: 02/23/19 10:01am Link  |  Quote  |  Print  |  Notify Moderator
That is a great price, hardly worth doing it yourself for that kind of money.
2006 GMC 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
Gulfcoast
Alabama
Posted: 02/23/19 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Some dealer's take bids on bulk oil and then take the best deal.
I want to see what I'm getting in a can, whatever the cost.
FishOnOne
The Great State of Texas
Posted: 02/23/19 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
^Does the regular dino Rotella still smell?
No... the smell went away with the API CJ4 version.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
Super_Dave
Harrisville, UT
Posted: 02/23/19 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know what the suggested replacement miles is based on? Highway? Hauling/towing? City? I'd think that use would play a big factor. My truck is used almost exclusively for towing.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
FishOnOne
Posted: 02/23/19 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Gulfcoast wrote:
2006 Cummins 5.9 - 150k miles.
I know nothing about this 5.9 that I just bought, except it really runs good.
I've always used Delo 400 in diesel engines, what do you prefer and why?
Thanks
Your current crop of diesel engine oils are now API CK4 oils and some changes have been made and some oil brands have taken a different approach when designing and marketing their oil. Some are oils are only rated for diesel engines(which are the ones I recommend) and some are diesel and gas engine rated (which are the ones I don't recommend). In addition the CK-4 specification removed the flat tappet valve train wear test requirement.
For your engine I would recommend Rotella, Valvoline Premium Blue or Motorcraft diesel only oils since the ZDDP anti wear additives are still above 1k ppm and these oils are only diesel engine rated and can be easily purchased at just about any store.
I would not recommend Delvac and Delo since they are now dual rated for both gas and diesel engines and the anti wear ZDDP have been reduced to ~800 ppm which allows them to be used in gas engines.
Whichever oil you choose be sure "NOT" to use any API FA-4 oils.
* This post was last edited 02/23/19 10:58am by FishOnOne *   View edit history
garyp4951
TN
Posted: 02/23/19 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Thanks
If you know nothing about fuel filtration, you better start checking it out.
Genos garage is a great site to get your filters from, and Glacier diesel has some better filter assemblies.
fj12ryder
Platte City, MO
Posted: 02/23/19 10:56am Link  |  Quote  |  Print  |  Notify Moderator
I ran Delvac 1300 non-synthetic, then switched to Rotella TTT as it was on sale, but the metal numbers started to climb in the reports from Blackstone Labs. I switched back to Delvac, and all the numbers started to drop, now everything is back where it was before the switch to Rotella. Blackstone Labs said
"While it's impossible for there to be absolutely no bearing wear in 4,599 miles, it is possible for it to be so low that we can't measure it, and that's what we've got here." I went 6,000 miles on the last oil change, and all is still excellent.
Cheap and good oil. An excellent combination. I can generally get a gallon of Delvac for around $13.
Howard and Peggy
"Don't Panic"
Gulfcoast
Alabama
Posted: 02/23/19 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Apparently, Valvoline Premium blue is recommended by Cummins, as it has their logo on the jug.
 > Diesel Oil.....
