RV.Net Open Roads Forum: Tow Vehicles: Lowering my dually?
Search only in Tow Vehicles
 > Lowering my dually?
Super_Dave
Harrisville, UT
Posted: 02/24/19 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know of an easy way to take 2" out of the bed height on my 2006 Ram dually? Would it create a domino effect to other suspension system changes?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
ACZL
UPstate,NY
Posted: 02/24/19 09:42am Link  |  Quote  |  Print  |  Notify Moderator
I removed the aux spring hangers so the springs wouldn't hit them w/ the 5er attached. Tho the truck may squat some, I don't get whammed when the truck goes over a bump and susp is trying to go back down if that makes sense. The suggestion came from posters on here.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Super_Dave
Harrisville, UT
Posted: 02/24/19 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Would you mind posting a picture of what that looks like?
parker.rowe
Delaware
Posted: 02/24/19 11:36am Link  |  Quote  |  Print  |  Notify Moderator
That might make it lower if you are on the overloads when it is hooked up, since as you said it will squat more.
But it won't change the unloaded bed height.
2015 Starcraft TravelStar 239TBS 6500 GVWR
1997 GMC Suburban K2500 7.4 Vortec/4.10 Gears
1977 Kawasaki KZ1000
camp-n-family
London, Ontario
Posted: 02/24/19 11:37am Link  |  Quote  |  Print  |  Notify Moderator
I can’t find a picture of the stock suspension but some trucks came from the factory with blocks between the springs and axle. Easiest way to lower a truck is to remove the blocks. If you don’t have blocks you can buy lowering kits for it online. They are usually new shackles for the leaf springs. Pretty easy job to change out.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
Durb
NW
Posted: 02/24/19 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
My fifth wheel has only 54" of overhang with a non-adjustable pin box. I took off the 1 ton overload springs and bump stops and installed air bags which are at the minimum 6 psi when towing. I needed two inches of squat to bring my trailer to level. The truck has some rake when empty and actually sits level when towing. I have been towing set up like this for four years with no adverse effects. About 2,300# in the bed. 2WD though. 04.5 Ram 3500 dually, also quad cab in silver.
You could put extra weight in your bed such as a large aux tank with fuel,
Super_Dave
Harrisville, UT
Posted: 02/24/19 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Are the 3 spacers under the spring pack what can be removed?
Posted: 02/24/19 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
^ Yup. Those are them. That'll do a decnwt reverse level like you're looking for without sacrificing any capacity.
Don't remove the upper overload contacts. That's not a good idea for your application.
(Nor does it provide any change in ride height until the truck is sacked out, but if it's sacked out, you'd want the extra springs)
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 02/24/19 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
You do not remove them you move them to the top of the spring. Down side it is the caliaper bolt can not be removed.
ACZL
UPstate,NY
Posted: 02/25/19 01:17am Link  |  Quote  |  Print  |  Notify Moderator
Your right. I was under the impression Dave wanted his towing height lower.
