RV.Net Open Roads Forum: Fifth-Wheels: Dometic Refridgerator stopped cooling
 > Dometic Refridgerator stopped cooling
Celticman
NV
Posted: 02/26/19 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
The flue is warm to the touch, so I'm unsure about the heat element being bad. I may take it out to have a look see. Maybe I'll change the fuses anyway. At this point I'm thinking control board.
Old-Biscuit
Verde Valley
Posted: 02/26/19 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
Celticman wrote:
Power cord is hot and fuses are good.
Lower circuit board.....bottom right side are 2 black leads that are for the heater element
They connect at J7 & J8
One is 120V AC HOT and other is Neutral/Common
Typically 'odd' are HOT and 'even' are Neutral/Grounds
So with Fridge in 'AUTO' and temp warm enough for thermostat to call for a cooling cycle....J7 should be HOT
Check resistance of element when measured at the 2 leads 44 ohms
Should have continuity when measured at the 2 leads
Dometic 3850644422 Heater Element
On Edit:
Flue warm.....element is 325W and should generate 350*F temps in order to boil the liquid ammonia into a vapor
IF element checks good
Then unplug fridge temp sensor leads (Thermistor)
Left side P2 connector....2 White leads
Run fridge for 12 hrs and check temps in freeze & food compartment.
Should be 10*F/lower in freezer and 38*F/lower in food compartment
This will test that cooling unit is functioning
* This post was edited 02/26/19 08:41pm by Old-Biscuit *
Celticman
NV
Posted: 03/05/19 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I don't know.... Everything is working. Everything checked okay. I went ahead and replaced the 2 fuses but the fridge had already started cooling down.
Perhaps a cooling unit blockage?
Thanks again for the input.
jkwilson
Indiana
Posted: 03/06/19 06:27am Link  |  Quote  |  Print  |  Notify Moderator
Hard to guess without some info about what was happening. Both compartments not cooling or not cooling enough? What temperatures were you seeing?
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Celticman
NV
Posted: 03/09/19 11:55pm Link  |  Quote  |  Print  |  Notify Moderator
Temperature for the fridge was 50's-60's. Freezer was 30's.
Now fridge is 30's and freezer is 0*- 10*
Ski Pro 3
Placerville, CA
Posted: 03/11/19 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like it's fixed then. Intermittent problems are usually bad electrical connections. Maybe something like Corrosion-X sprayed on connections will keep it from returning.
2006 Dodge Ram 4x4 crew cab w/diesel and manual tranny.
2012 Lance 855S camper
Celticman
NV
Posted: 03/13/19 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
Possibly? I checked the connections and they looked okay.
Well, thanks again to everyone for the input.
