RV.Net Open Roads Forum: Tech Issues: How much AC is needed?
 > How much AC is needed?
1320Fastback
Vista, Ca
Posted: 02/27/19 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
I'll throw in that some makes of ACs work better than others so it depends.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
BeerBrewer
Long Island
Posted: 02/27/19 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
I should have mentioned that the trailer manufacturer (Grand Design) claims that the trailer is well insulated. They state that it has R-40 in the roof, R-11 in the floor and R-9 in the walls in their brochure. The manufacturer also claims that the 15K BTU AC unit should work just fine and they have not gotten any complaints.
As for adding a second AC unit I was just curious and I was mainly interested in the actual AC unit install on the roof itself and all that goes with that, like sealing the roof and securing the AC unit its self. I wasn't that worried about the electrical aspect of the install and I don't mean to minimize that aspect of the install, its just that I'm an engineer and I've worked with electricity (AC and DC) my entire career, so I'm sure I could figure that out. All that said, I honestly don't think I'd ever do it. Seems rather crazy to plan on adding a second AC unit to brand new trailer. It would make more sense just to buy another trailer if the 15K BTU unit can't do the job.
bgum
South Louisiana
Posted: 02/27/19 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
You will not be unhappy with too much but will be unhappy with too little.
wrgrs50s
Scurry, Tx
Posted: 02/27/19 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
From friends with 2 Acs, the positives are:
Use the bedroom Ac when watching television since the living AC is so loud, and use living room AC at night so the bedroom is quiet. Have them run your living room AC and turn on your TV, you will notice that that can be a problem.
If one goes out you have a backup. Ask someone who has had that happen.
Most important: Never bank on what a manufacturer or salesman tells you when they are attempting to make a sale. Do more research and you will find that even a lot of the higher end rigs have difficulty in maintaining a comfortable temp when the outside temps reach near 100.
Walter and Janie Rogers
2012 Sundance 277RL
TV 2006 Silverado 2500 6.0
TXiceman
Full Time RVer
Posted: 02/27/19 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
In Texas you will want a second A/C on that size RV. End of discussion.
Amateur Radio Operator.
2edgesword
New York
Posted: 02/27/19 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
I'm an electrical engineer also on Long Island. The cost difference of doing it if you already have 50 amp service versus only having 30 amp currently is significant. That would be my only hesitation.
Wherever I happen to park
Posted: 02/27/19 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
Short answer NO.
Suggestion: put a 2nd 15000 BTU on it. ceiling controls (if you can reach the ceiling) that way it only needs 120 volt. I like Coleman's here for other reasons (They suck which in this case is a good thing. makes the condenser easier to clean. most others blow Way more work).
Run a 12ga line to a handy spot inside where you can install a SINGLE BREAKER switch. (note they make 20 amp breakers that mount in a standard wall box) from there to a 20 amp inlet on teh "Services" side of the RV and a 20 amp cord to the parks' 20 amp outlet from there.. fully independent of RV it will be so it won't trip a GFCI like a cheater box would.
Home is where I park it.
pennysmom09
Delaware
Posted: 02/28/19 05:49am Link  |  Quote  |  Print  |  Notify Moderator
. X2. Having 2 AC units is definitely a bonus for these reasons. On hot days we run both.
Nancy and Doug
2015 KZ Durango 325RL FW
2012Coleman
Posted: 02/28/19 06:12am Link  |  Quote  |  Print  |  Notify Moderator
You mentioned camping in summer in Texas and Florida. Not sure about Texas, but summer camping in Florida is hot and I'm very glad I had the dealer install the bedroom AC. It is most likely already wired for the AC. They offer two versions, one controlled by a thermostat which is more expensive, and one that just has the controls on the panel - no auto on/off.
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
dougrainer
Carrolton, Texas
Posted: 02/28/19 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Above 25 foot in length, I have NEVER had a customer come back in 40 years and state I wasted their money on the 2nd AC I insisted they needed above 90 degree heat. I HAVE had customers complain about the single AC that could not keep their 25 foot and larger RV cold enough in 90 plus heat. As others stated, you NEED 50 amp service for 2 AC units. UNLESS, you have a factory installed 30 amp EMS system that uses 2 low amp Colemans to run on 30 amp. Jayco uses such a system on certain 30 amp models. You need to look at RV's that come with 50 amp service. That way you can upgrade to a 2nd AC if needed without spending a lot of money adapting the electrical for that 2nd AC. Doug
