RV.Net Open Roads Forum: Fifth-Wheels: 6.7 Diesel fuel mileage
 > 6.7 Diesel fuel mileage
Cougarnewbie
Illinois
Posted: 03/03/19 08:05am Link  |  Quote  |  Print  |  Notify Moderator
noteven wrote:
I like the new Ford 7.3. It has pushrods and doesn’t need to turn 6thousand eleventeen rpm to do the work. Burns gasohol.
Wonder how it would pull if it had a turbocharger?
Where did you get your info on the new 7.3? I didn't think they had announced anything?
May All Your On Ramps be Downhill
larry barnhart
wenatchee. wa usa
Posted: 03/03/19 09:13am Link  |  Quote  |  Print  |  Notify Moderator
On the 7.3 gas ford and wanting a turbo. Don't buy the first model because the turbo will be out the next model year as an improved engine. I don't know anything but seems possible.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
neal10a
Madison CT
Posted: 03/03/19 10:34am Link  |  Quote  |  Print  |  Notify Moderator
I suspect the 2011/13 6.7 get better fuel milage than the 2019. The newer diesels have more power and torque. HP/torque consume fuel. My 2012 6.7 gets 18/20 not towing and 11/12 towing a 16500 40ft 5th wheel at 62mph highway. If the DPF cleaning did not kick in it would do about .5mpg better.
Bionic Man
Colorado
Posted: 03/03/19 10:37am Link  |  Quote  |  Print  |  Notify Moderator
chevman
I would be absolutely shocked if they added a turbo to the new 7.3. Talk about something that would get terrible fuel mileage.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
FishOnOne
The Great State of Texas
Posted: 03/04/19 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Actually there's been reports that owners of the '19 trucks getting better fuel economy than their previous year trucks.
I do agree that if it weren't for regens we would see ~.5mpg better fuel economy on the 6.7PSD.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
Travlingman
Jonesborough, TN
Posted: 03/05/19 11:36am Link  |  Quote  |  Print  |  Notify Moderator
I came from a 2012 F-350 dually with 3.73's to the 2017 F-350 dually with 4.10's. I lost 1 MPG loaded and unloaded.
2017 F-350 King Ranch DRW
2014 Landmark Savannah
JRS950
Posted: 03/05/19 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going a little different direction here. 3.31 gear ratio for towing? Please check the towing specs for that truck vs your trailer. That is a really high gear ratio. My Ram has 3.73 and I seriously looked at 4.10's.
Just my $.02 worth.
trailer_newbe
Tucson
Posted: 03/05/19 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
My new 2018 RAM gets about 17 around town. Towing on our last trip i got about 9.5 MPG, but the engine only about 900 miles on it. With my Tundra 5.7 I was getting 15.7 around town and 8 MPG towing. With that being said the RAM tows WAY better.
Regarding the Ford Push-Rod 7.3, it will not be the miracle engine to replace the diesel, sorry. It doesn’t come close to todays diesel torque, so it will still need to rev like a banchie. Put a turbo on it, and expect to need a 100 gallon tank. The 7.3 is designed to out-do the 6.4 RAM and the 6.3 GMC, period. Bragging rights...
2018 Jayco White Hawk 28RL
CabinetmakerII
Idaho
Posted: 03/12/19 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Cougarnewbie wrote:
Looking at a 2019 F-350 with a 6.7 diesel. Currently have a Triton V-10 that gets about 9 mpg. (about 6 mpg towing.) The sticker doesn't list mileage on the diesel. Wondering if the diesel gets better mpg and will it be enough to offset the higher cost of diesel fuel?(3.31 rear end)
Thanks
AL
Not sure if you will ever off set the price of the engine/fuel but I do know you will be happy with the power/torque of the diesel over gas. I would recommend 3:73 gear ratio over the 3:31. My 2017 F-450 has the 6.7 Power stroke with 4:30 rear end. I get 14MPG solo and 9 MPG towing... If the wind is blowing, all bets are off. Bottom line IMO, you cant beat a diesel when towing.
Regards
Allan
Cabinetmaker
2017 F-450 4X4, Companion 18K Hitch
2011 F-450 4X4, Companion 18K Hitch, Air Bags (Retired)
2012 Cyclone 3800, 5th Airborne Kingpin
2006 700 Arctic Cat ATV (X2)(Retired)
2014 Kawasaki Tyrex 4LE Side by Side
