RV.Net Open Roads Forum: Travel Trailers: Smoke Alarm
 > Smoke Alarm
beemerphile1
Ohio
Posted: 02/28/19 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure it is the smoke detector or are you guessing? Could it be the LPG detector, or maybe a CO detector? The LPG detector is powered by the RV's batteries and will alarm if those batteries are dead.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
RobWNY
Jamestown, NY
Posted: 02/28/19 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Soundguy. The problem with a switch is that the ceilings are so high in our 5th wheel that I need a step stool to reach it. I haven't measured but my ceilings have to be 10 feet high. I suppose I could move the smoke detector to the "Upper level" where it's easier to reach. Then a switch would work great.
If God didn't want us to eat cows, he wouldn't have made them out of Steak and Cheese.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
Bobbo
Wherever I park
Posted: 02/28/19 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Or, you could mount the switch on the wall within reach and run a pair of wires up the wall, across the ceiling to the detector.
Bobbo and Lin
2012Coleman
Posted: 03/01/19 05:18am Link  |  Quote  |  Print  |  Notify Moderator
My question is why you even have a battery in it while in storage? Agree with others, but you can read the label on it. Is should tell you what the beep pattern means.
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
Hondavalk
Toledo
Posted: 03/01/19 06:38am Link  |  Quote  |  Print  |  Notify Moderator
RobWNY wrote:
Anyone know of a smoke detector for the RV that doesn't go off when making toast? No smoke, No fire, Just your normal toaster doing it's thing. Sets our detector off every time.
An ionization smoke alarm contains a small amount of radioactive material. The radiation passes through an ionization chamber which is an air-filled space between two electrodes and permits a small, constant current between the electrodes. Any smoke that enters the chamber absorbs the alpha particles, which reduces the ionization and interrupts this current, setting off the alarm. This type of alarm responds best to fast raging fires.
Photoelectric smoke alarms operate using a light source, a light beam collimating system and a photoelectric sensor. When smoke enters the optical chamber and crosses the path of the light beam, some light is scattered by the smoke particles, directing it at the sensor and thus activating the alarm. This type of alarm responds best to slow smoldering fires.
A Photoelectric smoke alarm is a better choice in the kitchen. it will give fewer false alarms due to cooking.
RobWNY
Jamestown, NY
Posted: 03/01/19 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for that information Hindavalk. Since my camper only has one smoke detector, I think I'll buy the Photoelectric type and put it where the current one is and then mount the one I already have in the bedroom area.
CavemanCharlie
Storden,MN
Posted: 03/01/19 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
I changed to the photoelectric type in my TT. The regular detector would go off whenever I made toast.
Boband4
Wa
Posted: 03/02/19 08:29am Link  |  Quote  |  Print  |  Notify Moderator
I write the date on the alarm when I install them just to be able to keep track of how long they have been in service.
fallsrider
Raleigh, NC
Posted: 03/08/19 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Ours easily twists off the mounting base. I lay it on the nightstand in the bedroom while cooking in the kitchen.
Lynnmor
Red Lion
Posted: 03/09/19 06:26am Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
SoundGuy wrote:
SoundGuy....you are the Master of Switches! I know the OEM guys cannot install a smoke alarm shutoff, but they could follow your lead on some of the others.
Great install,
Jerry
I did mine slightly different.
 > Smoke Alarm
