RV.Net Open Roads Forum: Winegard DM elevation sensor . Loss of sat. signal REPAIRED
 > Winegard DM elevation sensor . Loss of sat. signal REPAIRED
klutchdust
Orange, California
Posted: 03/03/19 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
When I depress the button on the unit I get an error code. I went on the roof and checked and cleaned a connection with electronic cleaner, removed both connectors going to the circuit board as was suggested.
It is hard wired and has not had a 9 volt battery mounted to the panel.
expensive little sucker.
* This post was edited 03/13/19 02:52pm by klutchdust *
Bill.Satellite
Full-timer
Posted: 03/04/19 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Did you have a comment or question or did you fix it or what?
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
klutchdust
Orange, California
Posted: 03/04/19 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Good point. It still reads error code, any suggestions.
Chris Bryant
Arden, North Carolina
Posted: 03/04/19 11:24am Link  |  Quote  |  Print  |  Notify Moderator
I might try a 9 volt battery, in case there is some interference on the 12 v line
-- Chris Bryant
My RV Service Blog
The RV.net Blog
Bill.Satellite
Full-timer
Posted: 03/04/19 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
What error code is it reading?
klutchdust
Orange, California
Posted: 03/04/19 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Once the button is depressed two lines are visible then it reads e r . I installed a battery with no luck. I did read that you can count the crank rotations and it translated into a degree setting. Im going to try that once I get to the track and settled in tomorrow. They have a mobile mechanic that roams the area and has helped me out before when my fridge door fell off.
Bill.Satellite
Full-timer
Posted: 03/05/19 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Here is a link to the manual crank elevation chart.
http://www.winegard.com/kbase/uploads/2451067.pdf
If you are seeing error messages then you already have power so no battery is necessary.
If sounds like you have a bad sensor/connection on the roof as the DM is not seeing the sensor.
klutchdust
Orange, California
Posted: 03/05/19 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Is just the sensor replaceable.
Bill.Satellite
Full-timer
Posted: 03/05/19 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
If you use the chart a couple of times you will find that the Digital Magic device is completely unnecessary. It takes about 3 seconds to turn the necessary number of cranks and the elevation is set just as quickly as using the Digital Magic. The DM is great when setup exactly right and a disaster if it's not. Go with the chart and sit back and watch TV!
klutchdust
Orange, California
Posted: 03/12/19 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
UPDATE:
Back home again, went on roof and found the connector from the inside wiring to the outside wiring corroded. Spliced 3 wires together,heat shrink, silicone and we now have the elevation meter back in service.
Still not having results with getting the satellite to talk to the receiver. Most advised to replace the LNB. I have switched out the receivers but no results.
I use the signal strength guide that is on the TV and it shows zeros until you can find a signal. I notice that the process is slower than it normally is. It doesn't scan the zero's fast enough if that makes any sense.
