RV.Net Open Roads Forum: Travel Trailers: Parked Travel Trailer
 > Parked Travel Trailer
tchaytor
All Locations
Posted: 03/05/19 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Hopefully this is the right spot to post... if not give me the gears!! lol
I am looking to buy a used TT. 2011 to be exact. Its a Jayco 25BHS. I am not new to trailers I have had a hybrid for 3 years now. My question is this.
The Trailer is parked in a RV park and has been for 5 years. Has not been moved at all during that time. I had a quick inspection back a few months ago and it doesn't have any noticeable leaks etc.. looks well taken care of. I am going to go back in a month or so once the weather clears to have another look. Tires/brakes etc.. plus go over a few things. The trailer is used almost all summer by a lady and her daughter. My question is what things should I look for besides the obvious. Yes it has been winterized by a local RV company every year.
Thanks for your help folks!!
Terry
Iraqvet05
Greenwood, MO
Posted: 03/05/19 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
Get up on the roof and check the membrane, caulking, skylight and AC/vent cover condition. Check the condition of the slide (seals, motor, function). I'd plan to replace the tires since they are that old...all 5 of them if you are going to haul it around regularly.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
JIMNLIN
Oklahoma
Posted: 03/05/19 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
welcome to the forum Terry,
I would have the owners hook everything back up and see that its all in proper working order.
A 2011 trailer is not a old trailer. If it was me and I had bought the trailer the first thing I would do is replace those tires of ones of my choice especially after setting for that many years.
path1
Varies with weather
Posted: 03/05/19 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
X2 on above...and I wouldn't buy any RV new or used without doing a water pressure test on supply side.
the bear II
Torrance CA.
Posted: 03/05/19 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
If you plan on towing it you'll need to inspect the brakes, bearings, suspension, tires and wheels plus all underneath wiring, plumbing and tanks to make sure everything is road worthy.
downtheroad
Pacific Northwest
Posted: 03/05/19 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of good advice already from the posters above.
Leaks past or present would be the big one.
I will add that it will certainly need new tires...
Good luck with it all.
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
bob2194
Cache,Ok Gateway to the Wichita Wildlife Refuge
Posted: 03/05/19 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
If you are not sure you could have a mobile RV tech give it good inspection, might cost a few bucks, but would give peace of mind.
20 year U.S Army veteran and still serving. Vehicle inspector (ARMY)
2018 Radiance 28QB pulled by 2018 F250 STX 6.2 Gasser
Equal-i-zer Hitch
old guy
Oregon (pronounced Or e gun)
Posted: 03/05/19 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
the wheel bearings will need repacked, tires replaced,c heck the brake light covers , make sure the appliances all work, check the roof for chalk cracks, water pump works and the toilet doesn't leak any mold in the fridge?
tchaytor
All Locations
Posted: 03/06/19 06:49am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all for the great responses!! I live in Canada East so weather is not the greatest at this time. The trailer is "parked" but used every summer. In the summer its hooked to a constant water supply. Everything is in working order.. appliances, air conditioning, toilet etc... I am going to do a better inspection on the roof for caulking cracks etc.. also the I am aware the bearings tires etc will need a good looking into.. I don't suspect that will stop me as I understand the consequence of a parked trailer when it comes to brakes, bearings and tires. A local RV company always winterized this for her every season. I will check on that again though... thanks for the info folks.. I'll keep you updated!!!
K-9 HANDLER
Maryland's Eastern Shore
Posted: 03/09/19 05:03am Link  |  Quote  |  Print  |  Notify Moderator
If its a seasonal camper they are probably using electric instead of propane to power the fridge and water heater. One thing to check is those appliances will fire and stay fired on propane. Lack of use can cause the ignitors and flues in those appliances to corrode and become clogged with cob webs.
Camping near home at Assateague National Seashore with our wild four legged friends
