RV.Net Open Roads Forum: Fifth-Wheels: AUXILiARY FUEL TANK
 > AUXILiARY FUEL TANK
Page of 13
woodworker414
Crystal City,Mo.
Posted: 03/05/19 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
Good afternoon from chilly central FL.
I know I have asked this question before. I have entered the words in the search box, but no results.
Those of you that have added a AUXILiARY FUEL TANK.
Which one did you purchase?
Did you do the install yourself?
I am giving serious thought of putting one on the tuck this spring.
Your thoughts both pro and con.
* This post was last edited 03/09/19 06:01am by woodworker414 *   View edit history
Bill
WØWJU
Life is a trip, ENJOY the ride.
Safe Travels.
2015 Thor Motorcoach Chateau 31W
Toad: 2008 Chevy HHR
2015
hornet28
Muskegon
Posted: 03/05/19 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 50 gal. Transfer Flow system I installed myself. I bought it in 03 and transferred it to my 07 and had to buy new electronics for it then. Later I installed a used 90 gal Transfer Flow tank in my brothers truck. On his truck I used an electric pump with a switch on the dash, an in cab fuel gauge reading the extra tank and so he didn't forget he was pumping I put a pump on flashing LED light in the dash
2oldman
New Mexico
Posted: 03/05/19 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Spelled auxiliary in Tow vehicles
Spelled auxilary anywhere
Splashers3
Oakville, MD
Posted: 03/05/19 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 40G Titan aux tank added in the bed of my truck. I had a local diesel truck mod business install it. After some initial bugs (air in the line) it works great! It has LEDs which indicate the fuel level. The controller is inside the cab next to my steering column. I press the button and it adds fuel at a rate of 5 Gals in about 10 minutes...at which time it shuts off. I hit the button and the process starts again.
The folks at Titan are OUTSTANDING.
Good Luck.
Mike
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
laknox
Arizona
Posted: 03/05/19 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Bill, not trying to be the weight police, but do watch your payload and make sure the size tank you want will fit within your truck's specs. If you've not scaled your rig, ready to camp, I'd highly recommend doing so, so you know =exactly= how much payload you've got to play with. Heartlands aren't noted for being light. Just sayin'...
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 61 Year Member
B.O. Plenty
Minnesota
Posted: 03/05/19 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
62 gal RDS wedge with gravity feed. Drill 4 holes in bed. Three for mounting, one for fuel line. Install a grommet on fuel line hole. Install fitting from install kit in fuel filler hose. All you need to this is a sharp utility knife if the hose is rubber. I did one for my friend in 30 minutes total. Have had mine in two trucks now. Never a problem. Works perfectly.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
dmck413
Fluvanna Va
Posted: 03/05/19 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
40 gallon gravity feed. Came with fitting, wired in solenoid to control flow. LOVE IT. Fuel once a day
fj12ryder
Platte City, MO
Posted: 03/05/19 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have a generic 35 gallon steel from The Farm Store with an electric pump and hose/fuel nozzle. It gives me about 75 gallons total of fuel. Enough that I fuel up when I want rather than when the truck says I have to, wouldn't be without one.
Probably about $400 total spent. One of the best traveling accessories I've gotten.
Howard and Peggy
"Don't Panic"
packnrat
soon to be the state of Jefferson U S A
Posted: 03/05/19 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
i just have a cheap 36 gallon from tractor supply. i had to add in one bung so i could have a sight tube. but i just flip a man valve to gravity drain into the factory tank. but i did weld in a connection to the factory fuel inlet (yes it was off the truck for this). and yes a fuel filter in this assembly.
O and i did add in a grounding strap, needed?? i get a lot of static discharges. can hurt at times.
i went cheap and simple.
2006 F250 4X4 auto 6.0 short bed
2001 sunnybrook 24 ft
1984 cj7 built up a bit
kg6tgu
never too many toys, just not enought room to keep them
one dog who belives she is the master. rip 12 12 2007
12 loving years and loyal to the end.
just out having fun
azdryheat
Tucson, AZ
Posted: 03/05/19 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
91 gallon RDS tank with tool box that I installed. Absolutely love having all that diesel on board, good for about 1,000 miles towing my triple axle toy hauler and filling up when I want to and without the trailer.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
Page of 13
