RV.Net Open Roads Forum: Fifth-Wheels: AUXILiARY FUEL TANK
 > AUXILiARY FUEL TANK
Page of 13
hornet28
Muskegon
Posted: 04/08/19 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
There should be enough room. Too be sure measure from the hitch to the front of the bed. Then check the dimensions of the tank you want to buy
Edd505
Elephant Butte, NM
Posted: 04/09/19 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
sljohnson1938 wrote:
hi - I did not read all the replies, so I might repeat someone.
I do not have it now, but I got a 100 gallon "L" shape tank from Tractor Supply, also got a 12v pump to transfer tank to tank. Worked great for me.
80 gallon L [image]
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Crodad
Lafayette, LA
Posted: 04/10/19 06:44am Link  |  Quote  |  Print  |  Notify Moderator
I got mine from Here. This is the only place I found a tank I needed. I wanted it to be below the rails of the truck so I could close my Tonneau cover and I wanted about 45 gallons of fuel.
I brought to a shop to be installed. Mine is gravity fed. I have a shutoff valve on the tank. It drains directly into the tank. no need for a pump.
I purchased this because I hated going to gas stations with the %th wheel. most places are tight to get into. I don't like using truck stop pumps either. To much trouble going in leaving my credit card, pumping, going back in and paying. Now I only need to fill in the evening when we get to our destination.
2008 F-250 PSD 4x2 Lariat
2016 Silverback 31RK
MikeRP
Westerville
Posted: 04/14/19 06:28am Link  |  Quote  |  Print  |  Notify Moderator
I guess I should have looked here first! But I just bought a 46 gallon tank from ATI. It’s the #Aux 46.
I have a B&W companion slider hitch on the Ram puck system and this was one of the few tanks I could find that fit in the front of the hitch and underneath my tonneau cover.
It is gravity fed. Anyway, let me know if I made a bad decision or not?
Thanks!
nremtp143
Georgia
Posted: 04/14/19 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
I don't see anything wrong with wanting to carry more fuel. I use an ATI51 in my dually. Love the setup. To each his own. You'll be glad you have it..
2016 Montana 3790RD, Legacy Edition, G614s, TST TPMS
2008 Thor Vortex 26FS
2013 F350 DRW 6.7L 4x4, Edge CTS, B&W Companion, Viair 10007 Air System, Firestone Air Bags
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
woodworker414
Crystal City,Mo.
Posted: 04/15/19 05:56am Link  |  Quote  |  Print  |  Notify Moderator
Good cold morning form soth of St. Louis, MO. Should have stayed in the south longer. LOL
The install for the RDS 71783 RDS fith wheel tank is complete. Easy install. This is the 63 gal. tank. It will be nice to have that fuel on board. Now will stop when we want to.Probably after setting up at a cg.And it looks great. I will post photo when this computer goes to the photo gallery correctly.
Bill
WØWJU
Life is a trip, ENJOY the ride.
Safe Travels.
2015 Thor Motorcoach Chateau 31W
Toad: 2008 Chevy HHR
2015
garyp4951
TN
Posted: 04/15/19 08:03am Link  |  Quote  |  Print  |  Notify Moderator
RV.Net photo posting
MikeRP
Westerville
Posted: 04/16/19 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
packnrat wrote:
i just have a cheap 36 gallon from tractor supply. i had to add in one bung so i could have a sight tube. but i just flip a man valve to gravity drain into the factory tank. but i did weld in a connection to the factory fuel inlet (yes it was off the truck for this). and yes a fuel filter in this assembly.
O and i did add in a grounding strap, needed?? i get a lot of static discharges. can hurt at times.
i went cheap and simple.
Yes you need to get a good ground connection on the tank and usually that happens with the screws that hold it in place. Otherwise you need to get a wire from the tank to a clean part of the frame.
packnrat
soon to be the state of Jefferson U S A
Posted: 04/18/19 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
sad part of a extra supply of fuel.
is the cost to fill it.
i just put in $190.usd. but the extra tank was empty and the main tank had fuel in it.
interesting point, somehow i got 37 gallons in my extra tank? (lable says 35 or 36 full) but then i did round the dollar amount off a bit. and my sight tube says i still have two inches to the physical top of the tank.
but now for a good three weeks of not having to buy a drop of diesel fuel.
2006 F250 4X4 auto 6.0 short bed
2001 sunnybrook 24 ft
1984 cj7 built up a bit
kg6tgu
never too many toys, just not enought room to keep them
one dog who belives she is the master. rip 12 12 2007
12 loving years and loyal to the end.
just out having fun
hornet28
Muskegon
Posted: 04/19/19 06:48am Link  |  Quote  |  Print  |  Notify Moderator
What's really the difference? Pay many times or only once, still costs the same unless the price goes up or down between fillups
Page of 13
