RV.Net Open Roads Forum: Beginning RVing: Good boon-docking RV with good ground clearance?
 > Good boon-docking RV with good ground clearance?
Posted: 03/07/19 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
Welp, as they say. “There’s an arse for every seat.”
I’ll add, if you need axle flips, lifts, big trailer tires, skid wheels etc, you’ll beat the he!! Out of your truck getting the trailer there. Better make it a GN too so you don’t rip the 5ver hitch out of the truck bed while you’re smashing the nose of the trailer into the bed sides.
I’m all for modifying stuff to suit my wants or needs, but there’s a limit to what’s practical.
03 Arctic Fox 860
07 Dodge 2500 deezul
"Obviously I don't want to overload my truck and be unsafe, but the reality is the truck is way more capable than the 10K GVWR they put on the sticker.
KJ"
DrewE
Vermont
Posted: 03/07/19 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
For many trailers, at least, an axle at the far end would tend to bend or otherwise damage the frame if it carries weight at all frequently. They are not designed to be supported by the extreme ends, but rather from the middle primarily. I'm sure there are a few exceptions that are relatively overbuilt; however most RVs are about as far from being overbuilt as they can get away with, speaking generally.
memtb
Wyoming
Posted: 03/07/19 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
If the trailer has a good frame, lifting from the rear should transfer a substantial amount of weight to the tow vehicle. This is from experience .... once had to lift a 34’, 16000 pound 5er, approximately 4 1/2 to 5 feet from the rear....to lift it off of a 8” diameter steel post. Don’t ask! [emoticon]
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
BizmarksMom
Idaho
Posted: 03/18/19 10:52am Link  |  Quote  |  Print  |  Notify Moderator
I primarily boondock. That's why I went with a Nash travel trailer. Specifically the 22h. No slides. Well built suspension. Good ground clearance.
2019 F350 towing a Nash 22H
Posted: 03/19/19 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
Great. OP want's to boonydock a "huge 5th wheel." About as comparable as apples and spaghetti. I mean they're both food, but?
Ralph Cramden
Not on this rag of a forum
Posted: 03/20/19 03:20am Link  |  Quote  |  Print  |  Notify Moderator
I wish him luck if he's going to attempt boon docking in PA with that 41' monster. True Boondocking in PA is usually Allegheny National Forest or one of the PA State Forest districts. Not a lot of choices and the roads to where most of it is available are tree choked and little more than goat trails, especially to the dispersed sites in the state forests. I've done quite a few in both the state and ANF and can't imagine doing it with a 41' TH. It's hard enough with a 25' trailer that's only @ 11' high.
One would also have to consider doing it with an LCI frame. It would probably twist in half on that monster of a rig first time on one of those forest service roads. Better take welder and rod along with some misc pieces of iron just in case, maybe a couple of small wide flange beams.
cross21114
Baltimore, MD, USA
Posted: 03/24/19 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Plan B RV wrote:
memtb wrote:
For your rear overhang....you will eventually have an issue. We heavily recommend a good, heavy duty roller. Mounted beneath the frame, as close to the rear as is possible....as wide as possible! memtb
I have idea to install 7,000 lbs axle with 10 inch forklift tires. about 7" from rear of RV. With top of the tire recessed (about 3") into floor of rv.
Each tire rated at 2725 lbs.
Axle will be hanging until right before rear would have made contact with ground.
IMO, this wheel needs to be able to swivel. If not, you might rip the tire right off, or worse, making a tight turn. If you notice most trucks which have a pickup axle will raise theirs when entering a jobsite.
Chris
2018 Nexus Ghost 36DS
360 Cummins, 3000 Allison
2016 Ford Expedition
