RV.Net Open Roads Forum: Class A Motorhomes: 2008 Monaco Entry Step
 > 2008 Monaco Entry Step
monacorw
Posted: 03/06/19 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2008 Monaco Camelot with a Coach step and control module #301702. I replaced the magnetic switch for the door and now the step is not functioning properly. It still extends/retracts when door is open/shut. However, now it will not stay out when parked and the door is closed. It also will not retract with the ignition key is turned on. HELP!!!!
2008 Monaco Camelot
2012 Jeep Grand Cherokee Overland
ArchHoagland
Clovis, CA, USA
Posted: 03/06/19 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
What were the symptoms before you replaced the switch?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
PFGuil49
Baton Rouge, LA
Posted: 03/07/19 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Check the Entry Door Switch fuse (7.5 amp) and the Entry Door Sensor fuse (7.5 amp) located in the outside panel under the driver’s seat. The Entry Door Switch fuse is for the on/off switch on the dash/panel and the Entry Door Sensor fuse controls the steps when the ignition is turned on. Also, when you replace the magnets, were they like for like. My old ones was white with a ¾ inch bore so Coach Step advised me to replace them with the same color and bore magnets. I also had to replace my Entry Step Module because the old one shorted out and burned up. I installed module #301702, replaced both magnets (one in entry door and other in door frame), and all 3 fuses, step motor fuse (20 amp), Entry Door Switch fuse (7.5 amp) and Entry Door Sensor fuse (7.5 amp). Coach Step Technical Support was awesome. If this doesn't fix it, give them a call at 574-537-8900
hypoxia
Arizona
Posted: 03/07/19 06:24am Link  |  Quote  |  Print  |  Notify Moderator
One color of proximity switch is closed when near the magnet, the other color is open when near the magnet. Kwikee Step Magnet
Jim
2007 Monaco Signature Noble III ISX 600HP
PFGuil49
Baton Rouge, LA
Posted: 03/07/19 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Hypoxia, thanks for providing ArchHoagland the link. I replaced my magnets with Magnetic 3/4 inch Core Round, Kwikee part number 905314000 or Coach step part number 379400. Same part with different part numbers.
dougrainer
Carrolton, Texas
Posted: 03/07/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
1. Changing the magnet will not affect the ignition or kill switch
2. IF you installed the wrong magnet polarity, the step would operated in reverse. Retract when door is opened and extend when door is closed. The magnet just opens and closes a GROUND signal to the control module
3. Making the steps stay OUT with Ignition OFF and door closed is a 12 volt switch problem on the inside of the RV
4. Retracting the steps when the Ignition key is ON and the door must be closed, is a 12 volt problem on the Ignition side YELLOW wire.
5. So, you will have 2 problems if you have items 3 and 4 not working, and both will not be a magnet caused problem. Doug
MrWizard
Traveling
Posted: 03/07/19 11:02am Link  |  Quote  |  Print  |  Notify Moderator
That does not sound like a switch problem
That sounds like a control board problem
Radiate The Happy
1997 F53 Bounder 36s
dougrainer
Carrolton, Texas
Posted: 03/07/19 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
If it worked before the Magnet was replaced, then it would not be a control problem. Step controls rarely fail, UNLESS it is the older LCI/Coach/SCS step(NOT Kwikee). Those controls until about 2010 would fail as they were not sealed from the elements correctly. Doug
monacorw
Posted: 03/07/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing was working with the step
monacorw
Posted: 03/07/19 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the information. My problem is I don't have anything telling me which fuse goes to what other then the Monaco Operators Manual which has some fuses labeled but not all. There were a couple that labeled fuses as step. I checked them and they were good. I guess I'll just have to check every fuse in the box
