RV.Net Open Roads Forum: Anyone replaced their Schwintek slide with a pulley system?
 > Anyone replaced their Schwintek slide with a pulley system?
tvfrfireman
Portland, Or
Posted: 03/07/19 11:23am Link  |  Quote  |  Print  |  Notify Moderator
For two years we have struggled and had so many problems with our Lippert Schwintek slide that we were wondering if any of you have replaced or had it replaced your Schwintek with the pulley system? I understand that the slide needs to come out of the trailer but looks like a straight forward install. I have found one brand and am wondering if there are others and which system you prefer. Thanks in advance for any help. David
TXiceman
Full Time RVer
Posted: 03/07/19 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
The cable systems are no better than the Schwintek.
Amateur Radio Operator.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 03/07/19 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
The Cable systems have been around for a long time, then seems everybody jumped on the Schwintek Band Wagon, now many have switched back to the Cable system.
Our two main Livingroom/Kitchen are Hydraulic while our Bedroom is the BAL Accu-slide, which is OK, but I would have preferred Hydraulic since we already have the pump for the other slides and leveling jacks.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
filrupmark
Richmond,Texas
Posted: 03/07/19 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
We have the cable slide in the bedroom . No problem in 4 years
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
momentum rv
Central Cal.
Posted: 03/07/19 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Just in case you don't know, most scwintek issues stem from not holding the switch long enough after the slide motors stop. This extra couple of seconds will allow the motors to sync every time.
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
lee worsdell
elmvale
Posted: 03/08/19 05:13am Link  |  Quote  |  Print  |  Notify Moderator
I had 2 motors go on the schwintec slides on my rushmore while on vacation. Good thing the slides where in. They aren't hard to replace if you can push your slide out a few inches to get at them. But I coundnt get mine out so let the dealer do it
jffnkrn
peoria
Posted: 03/08/19 06:37am Link  |  Quote  |  Print  |  Notify Moderator
We are on our 4th year with the Schwintek in our Reflection, never an issue. Like said above, keep them in sink and you shouldn't have any issues.
Cummins12V98
on the road
Posted: 03/08/19 09:33am Link  |  Quote  |  Print  |  Notify Moderator
You have something to back up that statement?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
TXiceman
Full Time RVer
Posted: 03/08/19 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
We are full time and I go by the number of problems we see from other campers.
Ken
grampscamper
Toronto
Posted: 03/09/19 06:34am Link  |  Quote  |  Print  |  Notify Moderator
I'm not a fan of the Schwintek slide. I've spoken to RV techs that just hate working on them. A poor design in my opinion. Manufacturers use them to save weight and cost.
2019 Grand Design Reflection 337RLS
2017 Passport Elite 19RB
2017 Ford F350 Lariat CC SB 4X4 6.7 B&W Companion RVK3300
