RV.Net Open Roads Forum: Beginning RVing: Water Heater problems
 > Water Heater problems
Nancy E
Ohio
Posted: 03/07/19 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
We are having problems with the water heater on our 1991 Winnebago Warrior. We light the pilot light for the water heater and within a minute, it goes out. What could cause this and what can we do about it?
Thanks!
enblethen
Moses Lake, WA
Posted: 03/07/19 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Pilot light models use a thermal couple to operate the valve.
Check to make sure the thermal couple is directly in the flame
Clean the thermal couple with steel wool
Replace thermal couple
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Bobbo
Wherever I park
Posted: 03/07/19 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen is correct, except it is called a thermocouple.
Bobbo, Linda and the furry kid (45 pound rescue)
prichardson
Lafayette, La
Posted: 03/08/19 06:57am Link  |  Quote  |  Print  |  Notify Moderator
Ensure that there is a good pilot flame and that the tip of the thermocouple is in the pilot flame. With a pencil eraser polish the contacts where it is attached to the gas valve and DO NOT over tighten when reattaching (finger tight is enough). If it sill does not stay lit it is probably a bad thermocouple.
ktmrfs
Portland, Oregon
Posted: 03/08/19 10:21am Link  |  Quote  |  Print  |  Notify Moderator
yup. and thermocouples can go bad, generally they are reliable but can fail. good news is that they are reasonably easy to replace and reasonable cost.
Also make sure the pilot flame is good. even a tiny bit of debris in the orifice can be enough to limit the flame to a point where it won't be able to keep the thermocouple hot enough to keep the valve open. If cleaning the thermocouple doesn't solve the problem, take out the pilot orifice and clean it with a small diameter piece of wire and blow it out with a blast of air.
the gas valve protection circuit to turn off gas in the event of a loss of flame is very reliable, but also the thermocouple is a very low current output with high impedance driving a sensitive detection circuit that must run on very low current and voltage and keep the gas valve open. So, once a thermocouple has a low ouput voltage under load, the system is marginal. can be caused by a low pilot flame or dirty thermocouple or thermocouple on it's way out. Usually it is the thermocouple that fails, not the gas valve.
2011 Keystone Outback 295RE
Wherever I happen to park
Posted: 03/08/19 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
Though as someone said Thermocouples CAN go bad. Very rare
The thermocouple is two pieces of metal bonded or twisted together They are Two DIFFERENT metals (IE: copper and aluminum or steel) and when heated generate about 0.480 Volts.. This powers an ELectromagnet inside the thermostat valve.
The magnet is not strong enough to "Pull open" the gas valve. but when you push down on teh button or do whatever it says to do that opens the valve allowing you to light the pilot.
NOW.. HOLD THAT POSE (Button) for at least 1 full mintue after the pilot is lit
THIS IS THE #1 Failure mode (Operator error) in some cases 2 minutes.
Then releast it and turn the knob to ON.
Possible other issues
Bad thermocouple (Rare but it does happen)
Bad thermostatic valve (The magnet open)
Bad connection between them
Home is where I park it.
Nancy E
Ohio
Posted: 03/08/19 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you everyone! We will check all those things and try your suggestions. Thank you again!
Bobbo
Wherever I park
Posted: 03/08/19 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
This statement I disagree with. In my vast experience, every time that a pilot light would not stay lit, it was the thermocouple that had gone bad. That probably amounts to 3 times in my 64 years.
Posted: 03/09/19 07:28am Link  |  Quote  |  Print  |  Notify Moderator
And zero in my 68 years though I have had pilots go bad.
ktmrfs
Portland, Oregon
Posted: 03/09/19 09:53am Link  |  Quote  |  Print  |  Notify Moderator
my exerience. In my trailer WH or house WH haven't had a thermocouple go bad. But in my house gas fireplace I've had several fail and need replacing. Output voltage open circuit was fine, but with it attached to the load, voltage dropped well below the min voltage. New thermocouple, all good again..
The construction of a thermocouple is pretty simple and one would expect them to have a long life, and they are pretty reliable, but not 100%.
Often times they haven't failed, but the real cause is a poor pilot flame or a dirty thermocouple or connector. Check that before replacing one..
