RV.Net Open Roads Forum: Travel Trailers: Slide Out Mechanisms
 > Slide Out Mechanisms
djgarcia2
California
Posted: 03/08/19 01:51am Link  |  Quote  |  Print  |  Notify Moderator
Hello...Researching purchase of a new travel trailer for young family. Considering a handful of <30' models with bunks for the boys; Heartland Sundance, Mallard, Wilderness and Shadow Cruiser, Forest River Surveyor and Keystone Bullet.. From what I gather there are three primary slide out types, hydraulic, screw and cable. My question is about the type of mechanism each model above uses; which are less terrible than the others, and which to absolutely avoid? Thanks all! Doug
garyemunson
Reno, Nevada
Posted: 03/08/19 02:57am Link  |  Quote  |  Print  |  Notify Moderator
Hard to avoid getting anything without the Lippert/Schwintek style these days. It is actually a reliable system IF the install was done properly although the weaker sidewall construction of TTs (compared to motorized RVs) makes getting one built right a little chancy. With this type of construction, routine maintenance is crucial BUT much easier than on others. YouTube has several good videos, some by the mfg. that show how simple it is. Those who do not lubricate with the recommended CRC Power Lube constitute the majority of those who have issues. These systems had problems with everything in the beginning but are quite reliable now. The nice thing about them is with both a top and bottom gear rack on each side of the slide, the slide is held in place much better going down the road and the need for a piece of broomstick wedged at the top when closed is no longer an issue. Recently the aluminum racks have begun to be replaced with steel ones which should make the mechanism even more durable.
GrandpaKip
Flat Rock
Posted: 03/08/19 08:15am Link  |  Quote  |  Print  |  Notify Moderator
We have the BAL cable system on ours. No problems so far. It seems simple enough that I should be able to fix it if something does happen.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
ADK Camper
New york
Posted: 03/08/19 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
We have a schwintek slide on our 2012 FunFinder purchased spring of 2011. It's the first year Cruiser rv used this type. Ours has been trouble free and reliable. I especially like that it is flush to the camper's floor. There is no step up into the slide.
We did have one issue, but it had nothing to do with the slide's design. It was an assembly issue. There are rollers attached to the trailer's frame that support the slide as it moves in and out. One roller had been siezed with caulk and would not turn so it skidded along the bottom of the slide as it moved. Eventually this began to tear up the floor of the slide. I was able to free up the roller and reinforce the floor and have had no problems since. If you do have this slide, you should extend it and inspect the underside of the floor and the rollers to ensure you don't have a similar problem.
badsix
north bend or.
Posted: 03/08/19 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
we have the cable system and its about 12 years old. I have replaced some of the cables and done some adjustments, its very easy to work on. I carry a couple spare cables kits and other parts just incase. I could easily change them on the road, the only thing that couldn't be fixed on the road is the motor if you didn't have a spare. you can also move the slide in with battery operated drill and a flex drive to fit your motor.
Jay D.
Hannibal
Tampa Bay Area
Posted: 03/09/19 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
We’ve had three rack and pinion slide trailers. I won’t even consider anything else.
'10 F250 XLT CC SB 5.4L 5spdTS 3.73 101k miles
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'. Equalizer 4 pt 10k.
mosseater
Dillsburg, PA
Posted: 03/12/19 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
Same.
Sunset Creek 298 BH
djsamuel
Central Florida
Posted: 03/13/19 11:14am Link  |  Quote  |  Print  |  Notify Moderator
mosseater wrote:
Same.
Another vote for the rack and pinion.
Picture of Our Trailer
Camplite 21BHS
Timtation
Mid-West
Posted: 03/13/19 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
Rack and pinion. When all else fails, get out the crank.
timmac
Las Vegas
Posted: 03/14/19 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Power gear rack and pinion here also, I think its the best slide system on the market..
