RV.Net Open Roads Forum: Class C Motorhomes: Charging dead battery on Ford E350
 > Charging dead battery on Ford E350
CodyClassB
None
Posted: 03/08/19 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
I have 2015 Winnie Minnie 22 footer (Ford E350) . The battery is dead after sitting on the drive way for 6 months. I connected the charger to the chassis battery but it doesn't charge . I heard modern chargers don't charge completely dead battery and I do not have a spare battery. What is the best way to charge this dead battery ? thanks
* This post was last edited 03/08/19 03:45pm by CodyClassB *   View edit history
SidecarFlip
SE Michigan
Posted: 03/08/19 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Load testers are cheap.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
2oldman
New Mexico
Posted: 03/08/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure I'm following this correctly, but, you're connecting the new charger directly to a new battery and it doesn't charge?
theoldwizard1
SE MI
Posted: 03/08/19 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Modern battery chargers will NOT charge and absolutely DEAD battery. Jump start it, hold fast idle for about 10 minutes, shutdown and immediately connect the charger.
time2roll
Posted: 03/08/19 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Don't even have to start the engine.
Just jump, attach charger, start charging, remove the jump and let it rip.
For the OP: if you are plugged in or have solar you can add a Trik-L-Start combiner to keep the chassis battery charged. Letting any battery run that low will cause sulfation and permanent loss of capacity.
675w Solar pictures back up
2oldman
New Mexico
Posted: 03/08/19 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Need more info. At least I do.
CodyClassB
None
Posted: 03/08/19 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all . I updated the question. Since modern chargers do not charge completely dead batteries, will this cheap one charge ?
https://www.harborfreight.com/automotive........tomatic-battery-float-charger-69955.html
wolfe10
Posted: 03/08/19 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Perfect/correct answer!
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
4x4van
California
Posted: 03/08/19 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
That isn't a "charger", it's a "maintainer". It would likely take days with that to put enough charge into the battery for a normal charger to kick in. If ever.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 BW200, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
2oldman
New Mexico
Posted: 03/08/19 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update.
That's a battery maintainer, not a real charger. It would take a very long time. You hook that up for the 6 months you let 'er go dead.
You don't have access to a single battery anywhere.. like in another vehicle? Can't get a jump from someone? (to start the battery charging as said above)
