RV.Net Open Roads Forum: Travel Trailers: New shore power inlet installation
 > New shore power inlet installation
billroz
home lot
Posted: 03/13/19 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
A power cord coiled inside your rig is not safe
Atlee
Mechanicsville, VA
Posted: 03/13/19 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Indeed. My owner's manual says to pull the entire cord out of the "mouse hole" receptacle. I've always been told it's best not to keep a power cord tightly coiled when plugged in.
Erroll, Mary, Duffy the Dachshund (RIP)
www.thetravelingkoala.blogspot.com
2017 Jayco Jay Flight 23RB
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
And Blue Ox WDH/Sway Control
GrandpaKip
Flat Rock
Posted: 03/14/19 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Curious as to why. Only thing that comes to mind is possibly creating a magnetic field around the coil.
Adding an extension cord could lead to a voltage drop.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
wnjj
Cornelius, Oregon
Posted: 03/14/19 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Heat, but that’s only if you’re drawing a bunch of power.
SoundGuy
S Ontario
Posted: 03/14/19 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Which is why, if you're not using a detachable main service cable, you're better to cut the trailer's hard wired main service cable down in length so it just reaches outside where it's convenient to connect to an extension cable. In any case where I've done this that's always been 5' or less so voltage drop even at a full 30 amp draw would be an insignificant 0.30 volts over that short length of cable. No question, stuffing just a few feet of stiff 10 gauge cable back through the mousehole is FAR easier than trying to stuff in 25 - no tangles, no heat issue. [emoticon]
myredracer
Langley B.C.
Posted: 03/14/19 11:26am Link  |  Quote  |  Print  |  Notify Moderator
It's due to the "mutual heating" effect. For example, it's why code limits the number of romex cables going through a hole in a wall stud and why cords on electric space heaters shouldn't be coiled up. If you're drawing literally only a few amps, you'll be okay but if say in the summer with AC(s) and other stuff running, not a good idea.
One thing I really don't like about a cord stored in a box inside a TT is that it takes up a lot of valuable space. I converted a previous TT to a detachable cord and I was able to make the box's space accessible through an existing exterior storage door and gained an enlarged storage compartment. Bonus!
I hate CAPTCHA. CAPTCHA sux. CAPTCHA is evil. CAPTCHA needs fixing.
Gil, Deb & Dougal the Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH
2009 F250 super duty, V10, 8' bed, Hawkshead TPMS
Gulfcoast
Southeast
Posted: 03/14/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't know that
* This post was edited 03/14/19 12:49pm by Gulfcoast *
Lynnmor
Red Lion
Posted: 03/14/19 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a discussion from a few years ago: Old News
Gulfcoast
Southeast
Posted: 03/14/19 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
I did install the type that unplugs from the side of my trailer, it works great.
* This post was edited 03/14/19 04:52pm by Gulfcoast *
GrandpaKip
Flat Rock
Posted: 03/15/19 11:19am Link  |  Quote  |  Print  |  Notify Moderator
Kinda puts to rest the whole thing, doesn’t it?
