RV.Net Open Roads Forum: Can't get my Weber grill to cook quickly, Low flame
 > Can't get my Weber grill to cook quickly, Low flame
lamopar
Oregon
Posted: 03/09/19 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have my Weber grill hooked up directly to a conection on my trailer with a hose that was assembled for me at the gas place. Not a quick connect but screw together. My grill runs super low and constantly shuts off. I cant' get it to run correctly. Has anyone else had this problem? Iti is killing me trying to cook steaks.
Please help me on this one.
camp-n-family
London, Ontario
Posted: 03/09/19 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
RVs have low pressure systems through a regulator. If your Weber is hooked into a trailer line after the regulator it is being regulated twice. Once with the trailer regulator and one on the bbq. You need to remove the one on the bbq for it to work properly. See directions here.
* This post was edited 03/09/19 09:46pm by camp-n-family *
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
DownTheAvenue
Sunny South
Posted: 03/09/19 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
camp-n-family wrote:
If it’s hooked into a trailer line after the regulator it is being regulated twice. Once with the trailer regulator and one on the bbq. You need to remove the one on the bbq for it to work properly.
This is correct. The Weber Q series grills allows for the regulator to be removed. Remove it and all is well.
pbitschura
SE MN
Posted: 03/10/19 06:13am Link  |  Quote  |  Print  |  Notify Moderator
X3.
1988 Mallard class c 24' Chevy chassis 350 cu gas.
naturist
Lynchburg, VA
Posted: 03/10/19 06:50am Link  |  Quote  |  Print  |  Notify Moderator
Yup. X4
CaLBaR
Ontario, Canada
Posted: 03/10/19 06:51am Link  |  Quote  |  Print  |  Notify Moderator
X4 did this with mine. Saves me from hauling another propane tank along.
The other thing I need to do every so often is push a small paperclip end through the burner holes to push through the accumulated burnt on food drippings. Kind of a stupid design to have the burner holes at the top for this to happen. Love the grill anyway though.
2018 Grand Design Reflection 297RSTS
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L
HP Dual Cam Sway Control
Prodigy Brake Controller
lamopar
Oregon
Posted: 03/10/19 08:15am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the video. My system looks a lot like the one on the video but it was supplied by an LP gas company. They made the lines that connect to my trailer output and connect to my grill. My connections look a lot like the connection on the gas bottle and the end of the factory Weber grill. One screws into my trailer connection and it ends after about 10'. It is nice to have a ten-foot line to move the grill around with. The other attaches to the hose end they made for the grill which that hose is only 6-8" long and stays on the grill. I guess I will have to stop back at the gas place and see what they can tell me.
tomman58
Southeast Michigan
Posted: 03/10/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
For a few bucks you can totally rebuild the burner and the igniter. Clean the whole grill and it is new again. I know this isn't the answer to his ? but is good to do every couple years.
2015 GMC D/A, CC 4x4/ Z71 ,3.73,IBC SLT+
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
We have a granite fireplace hearth! Love to be a little different.
Bobbo
Wherever I park
Posted: 03/10/19 08:31am Link  |  Quote  |  Print  |  Notify Moderator
I, too, removed the regulator from my Weber. It works like a charm from the low pressure port on my trailer.
Bobbo, Linda and the furry kid (45 pound rescue)
lamopar
Oregon
Sorry, I also didn't mention I removed the regulator at the grill and the hose is attached just like the one in the video. I guess I could have something caught up in the hose or connections.
