RV.Net Open Roads Forum: Can't get my Weber grill to cook quickly, Low flame
 > Can't get my Weber grill to cook quickly, Low flame
lamopar
Oregon
Posted: 03/12/19 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry I didn't have pics available. I have attached them below. Now I hope this works! As I stated, all the connections are exactly the same as the connection on the top of the 1 lb bottle. I tried to take a picture of the line but it is too dark. The connection is near the front of the trailer, right off the main line coming from the bottles. The connector on the trailer is just like the top of a bottle (1 lb portable like from Coleman) and the hose end with the little protrusion goes into the connector. Same where the two hoses connect.
lamopar
Oregon
Posted: 03/12/19 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Well, that didn't work like I thought it would. Here is another photo. This is the end of the hose coming off the grill. Also, the hose that connects to the trailer and the hose end coming off the grill.
CA Traveler
The Western States
Posted: 03/12/19 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
By "main line" you mean bottles are connected to the regulator and then the main line - right? That is the low pressure "main line".
You have high pressure connectors for the hoses and connectors however. I'd bet the smaller orifices on the high pressure connectors are restricting your low pressure flow.
Go back to the propane shop and if they balk insist that they restore the BBQ so that you can demonstrate how it should work.
I would have large reservations about your propane shop but I'm certainly not a propane expert.
2004 CR-V and 2014 Grand Cherokee Overland
Bob
lamopar
Oregon
Posted: 03/12/19 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, the low-pressure side. That makes sense the connections are high-pressure fittings and restricting the flow. I think I will bypass the shop and buy my stuff directly and build it. I didn't know the fittings are high pressure and would reduce the gas flow.
I have all the parts for the grill and I am the one who took the regulator off the grill. I can put it back together to make it work with a little bottle. It may be easier to test it myself first to make sure there is no problem with the adjustable flame valve on the grill but it has never worked right since it was modified.
4x4van
California
Posted: 03/14/19 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, as CA traveler said, those fittings are meant to be used with high pressure, not low. That's the exact type of hose/fittings that I use to attach my BBQ to my RV, but my setup comes off the high pressure side (before the RV regulator) and I still use the regulator at the BBQ.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 BW200, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
lamopar
Oregon
Posted: 03/14/19 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks! I think I know the problem now. I'm going to get new lines and try this again. I bet the BBQ works much better after that!
SoundGuy
S Ontario
Posted: 03/14/19 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Which is what I described back on Page 2 of this discussion. [emoticon]
lamopar
Oregon
Posted: 04/23/19 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Just a follow up on the grill problem. I had the high pressure fittings on the hose and it was the problem. I ordered a new line with quick connects and valves and installed them. I have full flame and the grill works geat now. It was nice to be able to cook steaks quickly and burgers as well.
Thanks again for all your help on this problem. It is nice to learn from others.
