RV.Net Open Roads Forum: Class A Motorhomes: cummins "53"
tdgulfstream
santa rosa,ca
Posted: 03/10/19 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
im thinking of buying an 2001 holiday rambler endeavor with the cummins motor, does anybody know if the motor used is the "53" block which seems to be a bad issue (cracked blocks) in dodge trucks, wondering if its a concern in motorhomes also. Thanks, Tom
wolfe10
Posted: 03/10/19 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, 99-01 I would check the block. Yes, this applies to Cummins B engine ONLY.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
tinkerer
Wisconsin
Posted: 03/10/19 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
The years for these blocks were from 1998 to 2002, they were cast in Brazil. I had the misfortune of getting stuck with one of these failures in a MH.
wolfe10
Posted: 03/11/19 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Here is an explanation of the issue and years of production-- note, this is the year the ENGINE was built, so coach year could be somewhat later:
http://www.cumminshub.com/cummins-53-block.html
tdgulfstream
santa rosa,ca
Posted: 03/11/19 09:32am Link  |  Quote  |  Print  |  Notify Moderator
thanks for the response, I am going out this morning to check it out, this motorhome has 89,000 miles on it, i'll see what it looks like ...
CVD
Corona, CA
Posted: 03/14/19 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 1999 code 53 ISB. Had it 14 yrs, no problems (have to admit, was quite concerned when I learned about the potential issue after I'd bought the coach).
Re. what you are looking at, I believe the cracked block issue would have occurred by now. If it passes a pressure test now, I wouldn't worry.
Cliff
1999 Itasca 34V DP
2000 Jeep Wrangler
2014 Honda CRV
d_denver
California
Posted: 03/15/19 09:12am Link  |  Quote  |  Print  |  Notify Moderator
I believe the 53 block was only on the Cummins ISB. I doubt the Endeavor has the ISB small block
2002 34' Holiday Rambler Pusher
2005 VW Convertible toad
2008 Dodge 4x4 "Power Wagon" toad
wolfe10
Posted: 03/15/19 09:20am Link  |  Quote  |  Print  |  Notify Moderator
That is correct.
