RV.Net Open Roads Forum: Tech Issues: Atwood furnace not starting
 > Atwood furnace not starting
Rosslawncare
Camp
Posted: 03/11/19 07:48am Link  |  Quote  |  Print  |  Notify Moderator
My Atwood furnace will not start. When I turn the heat on I can only hear 1 click in the A/C unit. The fan will not start and I do not have any red blinking codes on the circuit board and fuses look good. I have reset the reset switch several times. Any help?
midnightsadie
ohio
Posted: 03/11/19 08:08am Link  |  Quote  |  Print  |  Notify Moderator
don,t no why you would hear a click in the ac unit. but theres some real good guys on here that will chime in. do you have a good 12volt hooked up? start your stove to bleed air out of the lines? thermostat set on furnace,,
enblethen
Moses Lake, WA
Posted: 03/11/19 09:51am Link  |  Quote  |  Print  |  Notify Moderator
The relay in the AC unit could have bad contacts.
Start by posting model of furnace,
If you can jumper the two blue wires in the furnace. This will by pass thermostat and relay. Furnace should start and produce heat. Remove jumper, furnace should go into cool down mode and shut off shortly.
If fan in furnce does not start, check for 12 volts DC at furnace.
Power present check for circuit breaker normally attached to fan housing on many models.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
1492
Arlington, VA
Posted: 03/12/19 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Posting Help and Support
dougrainer
Carrolton, Texas
Posted: 03/12/19 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
The click in the AC unit is the Furnace Relay closing sending 12 volt tstat power to the Furnace to start. IF the furnace operation fuse is blown, the furnace will not do anything. The tstat wiring(fuse) is separate from the furnace 12 volt wiring(fuse). You need to check for 12 volts on the RED wire going into the furnace. Doug
doxiemom11
Arizona
Posted: 03/12/19 11:48pm Link  |  Quote  |  Print  |  Notify Moderator
Need good 12 volt for the thermostat and circuit board so that furnace will operate. Start by checking there.
gatorcq
Arizona
Posted: 03/13/19 04:10am Link  |  Quote  |  Print  |  Notify Moderator
No voltage going to furnace. Verify that 12vdc is at the reset switch.
Next the click is the thermostat relay commanding heat. 12vd should be going to a blue wire on the control board.
Don't need to info as most Atwood operate the same.
12Vdc power
12Vd from thermostat
Sail switch
O/T switch
Blower comes on
LED MUST come on Red or Green (No LED = No Power)
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, 8800AH, Magnum Inv/Chg&Solar
Alfa SeYa 2003, CAT 3126E 330Hp (Previous)
DaGirslRV Blog
dougrainer
Carrolton, Texas
Posted: 03/13/19 06:03am Link  |  Quote  |  Print  |  Notify Moderator
You just joined. You MUST supply Year/Model/Brand of RV. Also the Brand and MODEL of appliance. Doug
starcraft69
northern California(State Of Jefferson)
Posted: 03/13/19 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
12Vdc power
Sail switch
O/T switch
Blower comes on
This is the correct troubleshooting "Follow the 12v" to the problem
2007 chevy 2500 HD 6.0 longbed
2015 Eagle HT 28.5 5th wheel
tucker the fishing dog
