RV.Net Open Roads Forum: Beginning RVing: Dewinterization in Campground
 > Dewinterization in Campground
rburrus
Virginia
Posted: 03/11/19 07:52am Link  |  Quote  |  Print  |  Notify Moderator
We store our Class C away from home and so have no access to water or electricity. We did successfully winterize our RV while parked. I am wondering if anyone has dewinterized their RV on the first trip out after winter?
2019 Jayco Greyhawk 30X
CarnationSailor
Carnation,WA
Posted: 03/11/19 08:28am Link  |  Quote  |  Print  |  Notify Moderator
I did it at the first campsite we stopped at. Just needed water at the site to do it.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
Johno02
Lexington, TN USA
Posted: 03/11/19 08:31am Link  |  Quote  |  Print  |  Notify Moderator
Yes, several times Usually because as I do not have a dump station at home, the campground s the first place I can flush the lines and tanks, and have a sewer line to carry off the water. If I flush lines at home, it all has to go in the tanks, which means I need to dump anyway. Our irst each year canpground has a good sewage system, and I connected to our local water system, which has good water. So we go with dry tanks, and antifreeze, and leave with fresh water in tanks, lines and water heater, and almost empty grey and black tanks.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and a grouchy, old, tiny dog
Johno02
Lexington, TN USA
dodge guy
Bartlett IL
Posted: 03/11/19 08:34am Link  |  Quote  |  Print  |  Notify Moderator
After dewinterizing thys also a good time to sanitize the fresh water system. A cup of bleach in the fresh water tank, fill it with water and run it through the lines. Let it sit for a few hours. Then drain the tank and fill with water and run through the system.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
BB_TX
McKinney, Texas
Posted: 03/11/19 09:48am Link  |  Quote  |  Print  |  Notify Moderator
We do it first trip each year.
ford truck guy
Pennsylvania
Posted: 03/11/19 10:50am Link  |  Quote  |  Print  |  Notify Moderator
We generally try to do it a week or 2 before our first trip in case there are any ISSUES...
There are years that the weather will not allow us to do that, then we just do it at our first campground.. No issues doing it that way, HOPEFULLY ! !
Me-Her-the kids
2015 Ford F350 SD 6.7
2020Redwood 3991RD Garnet
garym114
Bluff Dale, Texas
Posted: 03/11/19 11:09am Link  |  Quote  |  Print  |  Notify Moderator
Do it before you take off, never know what problems will come up.
Without power at your storage location I hope you disconnected the ground on your batteries. If you didn't they will be dead.
shum02
Burlington ON CDA
Posted: 03/11/19 11:26am Link  |  Quote  |  Print  |  Notify Moderator
You can do it at home? Dang!
First campsite I'm in it gets done there.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
BobsYourUncle
Calgary Alberta Canada
Posted: 03/11/19 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Why not? CG people can't tell if you are doing it. And it shouldn't matter anyways. Doesn't hurt anything. Just close the low point drains before leaving.
I always dewinterize at home first to make sure all systems are a go. But I understand some can't do that.
Welcome to the forum! [emoticon]
Dmax/Allison
1997 Triple E Topaz 27' Bunkhouse TT
I do
Precision Guesswork
based on
Vague Assumptions
Unreliable Data of Dubious Accuracy
provided by persons of
Questionable Intellectual Capacity
Now, What would you like done?
