RV.Net Open Roads Forum: Beginning RVing: Dewinterization in Campground
 > Dewinterization in Campground
Iraqvet05
Greenwood, MO
Posted: 03/11/19 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Our first trip of the season has always been to a CG where I get a site with full hook ups to dewinterize and sanitize the FW tanks.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
2edgesword
New York
Posted: 03/11/19 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
I do it at home since I like to insure the hot water heater is working before I leave for the first trip. The couple of gallons of anti-freeze I use to winterize and the few gallons of water used to clear the lines that gets flushed into the holding tanks shouldn't be an issue when traveling to the first campsite of the season.
allen8106
Burrton. KS
Posted: 03/11/19 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
rburrus wrote:
We store our Class C away from home and so have no access to water or electricity. We did successfully winterize our RV while parked. I am wondering if anyone has dewinterized their RV on the first trip out after winter?
2019 Jayco Greyhawk 30X
Yes
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 26
valhalla360
No paticular place.
Posted: 03/12/19 06:18am Link  |  Quote  |  Print  |  Notify Moderator
Yep. Also winterized it at a park last year.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Dick_B
Palos Heights, IL USA
Posted: 03/12/19 07:05am Link  |  Quote  |  Print  |  Notify Moderator
After sanitizing one now has a system full of bleach water including the Fresh Water tank. My latest trick is to open the FW tank drain when leaving the campground and let it dripple onto the highway. It's usually gone in time for the next stop/campground.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
Veebyes
Posted: 03/12/19 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Standard MO for us. No home to take it to. A CG is last stop before storage & first stop after storage.
2007 Alpenlite 34RLR
Lynnmor
Red Lion
Posted: 03/12/19 08:21am Link  |  Quote  |  Print  |  Notify Moderator
You sir have no consideration for others. We don't want your mess on our vehicles and particularly on motorcyclists, bicyclists or pedestrians. [emoticon]
Veebyes
Posted: 03/12/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
I do the same thing to finish draining the tank. Do you have any idea how little that dribble is or how diluted it is even if it has a little chlorine in it? Most low point drains are not even 3/8" diameter pipes.
JaxDad
Greater Toronto Area
Posted: 03/12/19 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
I ‘de-winterize’ 4 to 6 times a year, it’s complicated.....
Add water.
I blow the lines clear just before / after hitting freezing temps on the way north, and add water just before / after hitting above freezing temps on the way south.
I may be taking a big risk doing it this way, and I may regret it one day......
But then again I’ve only doing it this way for 35 or so years, time will tell.
memtb
Wyoming
Posted: 03/15/19 09:52am Link  |  Quote  |  Print  |  Notify Moderator
It can be done.....though I prefer to do at home, if possible! If an issue arises, we’re at home to better fix the problem....tools, parts, local hardware store, etc.!
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
