RV.Net Open Roads Forum: Truck Campers: FW capacity
 > FW capacity
Page of 7
Gjac
Milford, CT
Posted: 03/11/19 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
I just started looking on line at TC's and noticed there are not many units that have more than 30 gals of FW. Those of you that dry camp most of the time which I assume most of you do where do you store extra water?
jimh425
Western MT
Posted: 03/11/19 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
My Host has 60. I think there are other brands with more than 30 as well. I haven’t needed extra water so far.
sbryan@vtbryans.com
Vermont
Posted: 03/11/19 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Northstar Igloo and we have 40 gallons of fresh water. What really makes that work for us is the cassette toilet, which has its own 5 gallon water supply and that can be used with very little water. We also carry jugs for drinking water and mostly use the FW thank for showers and dish washing. It's amazing how little water you can get along with if you try.
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
work2much
Jackson Ca
Posted: 03/11/19 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
Our last three campers have had 50+ gallons of fresh water. If you need to carry more the back seat of the truck is a good place to put your jugs. Use a restraint to keep them in place in case there is an accident to avoid them smacking you.
Try and pack your heaviest stuff as far forward as possible.
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2018 Host Mammoth. 1080 Watts solar. 600 AH usable LFP battery. Magnum 2800 Watt inverter.
2018 Jeep Wrangler Unlimited toad.
Gjac
Milford, CT
Posted: 03/11/19 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
Which campers besides the Mammoth have 50 gals or more of FW? Is the Mammoth the largest TC on the market? Do you need a DRW truck to haul these campers with higher FW capacity?
Gjac
Milford, CT
Posted: 03/11/19 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
I just looked at your model online, looks nice with a dry weight of 2600 lbs, I am guessing that the traveling weight would be less than 3600 lbs, does that mean a truck with 4000 payload would be sufficient to haul it? Also I notice that the new Ford F150 with the 3.5 eng has a payload of 3700 lbs would this be sufficient?
work2much
Jackson Ca
Posted: 03/11/19 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Both our Bigfoot and Arctic Fox had 50+ gallon tanks. Not sure about others, these are just the ones I have owned.
We have a dually that we used on our last camper (Arctic Fox 1150) as well as our current Mammoth. I have seen them on SRW trucks but we like the dually ourselves.
Edit: Eagle Caps larger campers also have very large tanks.
rider997
California
Posted: 03/11/19 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Arctic Fox campers generally have 50+ gallon fresh water capacities. We carry another 5 gallons of drinking water in the under-dinette storage area.
Troutguy
Midwest USA
Posted: 03/11/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
Arctic Fox1140= 59gal. fresh water..
2018 RAM 3500 Crew Cab 4x4 DRW Cummins HO, Aisin trans and 4:10 gears, 14,000 lb GVWR
2018 Arctic Fox 1140 Truck Camper & Honda EU2000
Posted: 03/11/19 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
AF860 = 50 gal I believe.
I carry extra water in a ballast bag (think bladder) that we use for ballast in our boat. Folds up small when not in use and the same 12V pump for use on the boat works well to get water transferred into the camper tank.
400lb ballast sack fits nicely on the back seat floor, seat or in the truck.
Page of 7
 > FW capacity
