RV.Net Open Roads Forum: Beginning RVing: Need Front Brush Guard Bumper Grille Guard
 > Need Front Brush Guard Bumper Grille Guard
frederick2019
los angeles, CA
Posted: 03/11/19 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Got a 2012 Land Rover Range Rover Sport Supercharged 8 Cyl 5.0L to pull our toy hauler. I want to put a Front Brush Guard Bumper Grille Guard of some sort on the front. I do not believe they make them. Does anyone know of a fabricator whom can make one? I am in Calif. Thanks
PS some places say they have it on google searches but when you get into a specific grille guard it says no not available - hence I think I need a custom person to make it.
* This post was edited 03/11/19 06:19pm by frederick2019 *
Crestview area, Inyo County, California
Posted: 03/11/19 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Not knowing much about Range Rovers, do you have the payload for this, IMO, rarely needed accessory? “Pulling” is seldom an issue. Carrying ability is.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
BarabooBob
Baraboo, WI
Posted: 03/11/19 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
I just did a Google search and found several sources for front bumper guards for Range Rovers. I don't know your model or year to get specific information.
Bob & Dawn Married 30 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
SidecarFlip
SE Michigan
Posted: 03/11/19 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Call a local weld shop and have them build you one.... All it takes is money.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
hornet28
Muskegon
Posted: 03/11/19 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have any friends who weld or that may know someone who does?
Home Skillet
Pearland Texas
Posted: 03/11/19 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
You can ditch the front bumper and have one of these built.
LINK
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
Gonzo42
California
Posted: 03/12/19 08:25am Link  |  Quote  |  Print  |  Notify Moderator
I have pieces from WAAG, in Van Nuys, CA. 818-989-5008
You might check with them and see if they still make them.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
frederick2019
los angeles, CA
Posted: 03/12/19 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Thanks so much for the great ideas.
frederick2019
los angeles, CA
Posted: 03/12/19 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Home Skillet - that is a really nice bumper wow! The price comes with a wow too.
hornet28
Muskegon
Posted: 03/12/19 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
How large do you want? All the way across the front or just the center? Integral with the bumper or an add on? If just an add on most are quite flimsy. I had an add on it looked great and was stainless steel so no rusting. However I couldn't stand the way it vibrated plus it would've crumpled if I'd hit a deer. I built this one after taking the add on off. It's 2x2x1/8 sq tubing. The way I built it is the tubing bolts on in place of the factory tow hooks, comes out bent at a 90 degree angle upright goes up and across where the 2 sides meet. Where it's bent at the bottom it's braced top and inside with 2x2 tubing gussets. The hitch receiver is also well gussetted. I then had it powder coated. I also have a pair of high watt lights that mount on the crossbar. I forgot to add, the triangle plate you see on the bottom was put in after I added the second bottom bar and receiver as I also have a 12K winch set-up that can be slid into the receiver. I'm confident it'll hold as I got to far off on the shoulder with a 7K? trailer in tow and both truck and trailer had axles sitting on the ground and a snatch strap around the guard was used to pull it out. That happened before adding the receiver and plate
* This post was edited 03/12/19 08:28pm by hornet28 *
