RV.Net Open Roads Forum: Class A Motorhomes: 2004 Workhorse chassis; no sway bars?
 > 2004 Workhorse chassis; no sway bars?
4x4van
California
Posted: 03/12/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Have had this RV (2004 Itasca M30) on the Workhorse W-20 chassis for about 2 1/2 years now, and love it. But, realized something surprising the other day.
To be honest, I am not unhappy with the handling. Although it was a bit squirrely when I first purchased it, adjusting the tire pressures to match the actual load helped a great deal. However, I was still contemplating adding a rear trac-bar to improve things even more.
Imagine my surprise when I was rolling around on a creeper underneath doing some recon for a trans temp gauge install, and realized that there are NO sway bars on this chassis! None! So now I'm thinking that sway bars may be the best "Bang-for-buck" on my rig rather than a trac-bar. Heck, even my last 2 RVs (class C) had sway bars; I would've expected a bigger, heavier, taller class A to have them.
Thoughts? Is the lack of sway bars normal for the Workhorse?
* This post was edited 03/12/19 02:31pm by 4x4van *
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 BW200, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
rgatijnet1
Posted: 03/12/19 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
The sway bars are there and they are more beefy than any aftermarket sway bars. They are the large square tubes that are near both the frnt and rear axle and they are SOLID mounted, with no rubber bushings to dampen their affect. You can add others if you want to but it is a waste of money. You would be surprised how many people have added others and not realized that the chassis already have them. They usually swear that after spending a lot of money, the handling MUST be better. [emoticon]
I had no trouble with my "W" series Workhorse chassis so you may want to have the alignment checked and set your tire pressure at the correct psi for your weight. Since I traveled a lot in the Great Plains which is notorious for high winds, I added 4 corner air bags that I could inflate or deflate from a dash button. This stopped any swaying in high crosswinds. I also added Koni FSD shocks.
4x4van
California
Posted: 03/12/19 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, what a great piece of info. I saw the square bar across the leaf springs but never considered those as sway bars. Thanks; at 57 I'm still learning every day.
Wherever I happen to park
Posted: 03/12/19 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
One of the differences between Workhorse Custom Chassis and nearly everybody else.
They built MOTORHOME chassis's. NOt Truck but MOTORHOME So they put on as the other respondent said Big Heavy Square Solid Sway bars that do a good job.
They know Motor homes are top heavy and need the added sway control.
Most companies build like a straight truck chassis and .. Well.. those have a much LOWER center of gravity.. I know.. I worked out of one for 7 years.
Home is where I park it.
GREGORYJ
Lac Du Bonnet, Manitoba
Posted: 03/12/19 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Here is the rear sway bar for example on our 08 W22. After market ones are available for the W22 (one company is Roadmaster) but I'm not sure about the W20 chassis. To me it doesn't seem that effective when noticing how much the coach rocks side to side when pulling on or off some approaches and on to a highway.
Update: It appears the W20 and W22 use the same sway bars offered from these 3 companies, Blue Ox, Roadmaster and Hellwig.
* This post was edited 03/12/19 10:21pm by GREGORYJ *
Ellen & Greg
08 National Dolphin DL-35Ci
Workhorse W22 Towing 08 Smart Car
23hotrodr
Iowa
Posted: 03/13/19 04:55am Link  |  Quote  |  Print  |  Notify Moderator
Just FYI- I added a rear track bar to our 36' rig on W24 chassis and it helped tremendously with cross winds and passing trucks.
2007 Itasca Suncruiser 35L
2000 Jeep Wrangler
GREGORYJ
Posted: 03/18/19 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
23hotrodr, agree. Once it warms up here, I just got a rear track bar that I'll install plus a Road-Master sway bar. I fact going one more step, I'm removing the old square tube sway bar to make room for Kelderman's 2 stage Workhorse rear air suspension.
