RV.Net Open Roads Forum: Travel Trailers: residential refrigerator vs normal RV fridge/freezer
 > residential refrigerator vs normal RV fridge/freezer
Boband4
Wa
Posted: 03/14/19 06:45am Link  |  Quote  |  Print  |  Notify Moderator
If considering switching to a residential unit keep two things in mind. 1st - many say they like the residential because it has more capacity. Is there space in the floorplan for it to fit? My TT is 30 foot, and the furnace is under the fridge. There isnt room for a larger unit to sit on the floor. 2nd - and more important - if you are thinking of switching ensure the residential unit will fit through the door. I had to replace my gas unit and the only way to get the old one out and the new one in was to take the door off the refridgerator. I had less than 1/2 an inch clearance to fit through the TT door. Measure carefully!
trail-explorer
NM
Posted: 03/14/19 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Vintage465 wrote:
Since I do mostly boon docking and cant stand the sound of generators I'm in the Gas Refer camp. Any solar I have is going to keep my 4 each 6v batteries up so if it gets cold I and need to use the furnace, I can. Personally I don't see the day when I go to a 110v refer for camping.
DITTO.
I don't mind a generator for occasional charging, but with a residential fridge, it's likely you will need to run the generator several hours every day (and listen to the noise of said generator).
WHat happens if the inverter fails? then your fridge is kaput unless you have a generator to run non-stop until you solve the inverter problem.
Bob
2oldman
Salton Sea
Posted: 03/14/19 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
trail-explorer wrote:
wHat happens if the inverter fails?
Unlikely, but as with many things about this life, you carry spares.
