RV.Net Open Roads Forum: Fifth-Wheels: 55 Amp Converter Question
 > 55 Amp Converter Question
Jimbee
New York
Posted: 03/12/19 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
Hey All,
Our camper spec sheet says it came with a 55 amp converter. Just curious, 55 amps of what? Is that maximum charger output for charging the batteries?
Thanks!
2oldman
New Mexico
Posted: 03/12/19 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, 55 amps @ 13 volts to the battery. About 6 amps on the 120v side.
enblethen
Moses Lake, WA
Posted: 03/12/19 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
It is total output of the converter. A portion may go to the 12 volt DC devices connected and then the remainder goes to the battery.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Old-Biscuit
Verde Valley
Posted: 03/12/19 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
YEP^^^^
Total amperage converter is capable of supplying to DC Dist Panel (Fused load) and Charging of batteries
time2roll
Posted: 03/12/19 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
55 amps of DC power for the RV.
675w Solar pictures back up
SailingOn
Central Texas
Posted: 03/13/19 11:54am Link  |  Quote  |  Print  |  Notify Moderator
You might think therefore that if you have a 100 amp-hour battery bank which is 50% depleted, this converter will recharge it in an hour or so.
It doesn't work out that way, actually taking much longer. As the battery nears a full charge its resistance increases so it will accept less current, regardless of the peak output of the converter. Assuming that other 12V loads aren't large, using a higher output converter won't make much difference.
See The 12 Volt Side of Life
* This post was edited 03/15/19 08:37pm by SailingOn *
Buck: 2004 Wilderness Yukon 8275S, now memories.
Star: Open range LF297RLS. 2 air conditioners!
Togo: 2014 Winnebago View Profile, 2013 Sprinter chassis; 16 mpg
AJ: 2010 F150 ExtCab, 2WD, 6.5' bed, 5.4L V8, 6A, Max Tow: 2030# payload.
AD5GR
2oldman
New Mexico
Posted: 03/13/19 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
SailingOn wrote:
You might think therefore that if you have a 100 amp-hour battery bank which if 50% depleted, this converter will recharge it in an hour or so.
It doesn't work out that way,.
It's like filling a jug with water. You can fill most of it with high pressure, but not that last 10%.
Doing a lot of dry camping you rarely get 100% charge without solar.
