RV.Net Open Roads Forum: What chassis battery cutoff switch do you like?
 > What chassis battery cutoff switch do you like?
Naio
Snug as a bug in a rug
Posted: 03/13/19 11:33am Link  |  Quote  |  Print  |  Notify Moderator
I'm getting tired of pulling the negative terminal on and off :-). I see there are the kind where you turn the knob, the knife blade kind, a remote control kind, a hard wired remote switch on the dashboard... What's good?
I have a lot of bad back days when it's hard for me to lift the hood of the van, so the remote-controlled type was very tempting. Cheaper and easier than wiring some giant cable up to the dashboard. But I see an Amazon reviews that it (the one I was looking at it anyway, for $50) uses an electromagnet, and will drain my battery if I forget and leave it on.
What do you use, and why?
* This post was edited 03/13/19 12:06pm by Naio *
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
red31
Bryan
Posted: 03/13/19 11:37am Link  |  Quote  |  Print  |  Notify Moderator
This one looks interesting
Naio
Posted: 03/13/19 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Thanks! I guess I should also ask how many amps a switch needs to be good for? I'm realizing that a little car type cutoff switch might not withstand starting my big van engine...
agesilaus
North Florida
Posted: 03/13/19 11:50am Link  |  Quote  |  Print  |  Notify Moderator
I have the impression that many people, me included, use the Blue Seas switches. You can either get a straight cut off or one that does that and also switches between battery banks.
Switches
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
bob213
Fresno, CA
Posted: 03/13/19 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
I have two batteries but no need to switch between them. I use the Blue Seas 6006.
Naio
Posted: 03/13/19 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
I see my meaning was not clear! You know how it is when something is clear in your head and you don't realize it can be interpreted another way :-). I have now edited the title to specify that I'm asking about the chassis battery, not house batteries.
George3037
Central Square, NY
Posted: 03/13/19 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
I use the cheap battery cut off for my classic car when stored in the winter. Costs about $5 on ebay and has worked for me for many years.
I have thought of getting the remote operated disconnect switch but so far what I have works fine.
DrewE
Vermont
Posted: 03/13/19 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Rather than a shut-off switch, maybe using a small solar maintainer would be sufficient to keep it up even with the parasitic loads of the chassis? It depends on where you're storing the vehicle. This also works against self-discharge, which can be rather substantial in warm or hot conditions (and much less so in cool or cold ones).
For a day or a week or two, it should not be necessary to disconnect the chassis battery.
RLS7201
Posted: 03/13/19 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
I see no one noticed you bad back days. With this relay you can just push a momentary rocker switch from inside your RV.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
maillemaker
office
Posted: 03/13/19 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
I use the cheap one pictured above with the green knob.
However, they are cheap and the plastic knob will spin on the brass insert. To stop this, I cross-drilled the knob and brass and pressed in a pin. Now the plastic knob will not spin on the brass.
Steve
1990 Winnebago Warrior. "She may not look like much but she's got it where it counts!"
