RV.Net Open Roads Forum: General RVing Issues: RV Pole Barn
 > RV Pole Barn
Page of 7
pennrver
Pennsylvania
Posted: 03/13/19 11:46am Link  |  Quote  |  Print  |  Notify Moderator
We don't own an RV yet, but plan on purchasing one within the next year. Planning on putting up a pole barn to house it. We will build that before getting the RV. Wanted to see if anyone has any thoughts on it, mistakes you made, etc.
Dimension wise I want to be able to plan accordingly. We have pretty much decided on a class C, but may move on to a fifth wheel down the road. So I want to "future proof" the barn.
A fifth wheel is going to be taller than a class C, so if I plan my barn around that fact it should be able to hold any class C. What is the tallest 5th wheel right now? 13' something? so a 14' door should suffice?
Any thoughts on barn dimensions? I am looking for more of a multi use barn but primarily for the motorhome. But may be storing tractor, car, boat, etc. So looking for two bays.
Should I make it long enough to hold 5th wheel + truck attached? That might stretch it too long. How about room around the camper?
Looking to hear thoughts from anyone who has been down this road! Thanks
gbopp
The Keystone State
Posted: 03/13/19 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have a pole barn or other inside storage. But, the general consensus seems to be build it a little bigger than you think you will need.
You may want a 45' Prevost someday.
4aSong
Northwest Arizona
Posted: 03/13/19 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
We built an enclosed insulated RV garage a few years ago and besides the height which you already have I would suggest at least a 24'w x 40'd. Ours has worked fine for us and still have room for parking another vehicle either next to or in front of it. Had considered a metal building, pole barn and other covers but the winner was the enclosed insulated drive thru stucco and tile roof garage, the RV stays very clean.
Mike and Nancy
Tundra TRD V8 4WD w/Leer Shell
Lance Model 1985 - The Kramalot Inn
EU2000i * Prodigy * McKesh * Trek * Renogy * ENU
Bionic Man
Colorado
Posted: 03/13/19 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
It is a lot less expensive to build bigger the first time than it is to have to renovate.
I would recommend a 14' door. Should be able to get any future purchase in it.
If you can make it long enough to keep truck/5er attached, there are advantages to that.
My original building was 24' x 52' with 16' sidewalls. I then enclosed one side and added about 12' x 30'. I wish I would have made it wider still, as it is nice to be able to have the slides out when it is in the garage, and still be able to move around inside the garage easily.
I have power outlets every 8'. And (I think) 16 LED lights in the main garage.
Sky lights and lots of windows for natural light.
Insulated so it can be heated in the winter.
The area where the utility trailer is where I did the addition.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Tom/Barb
Oak Harbor, Wa
Posted: 03/13/19 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
Bigger is better,, 40 by 60 is as small as I would go. Leave room for a work shop.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
DrewE
Vermont
Posted: 03/13/19 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Legal maximum height for vehicles in the US (without oversized permits) is 13' 6", so a 14' high entry into a garage or pole barn should be sufficient for any RV unless the ground and/or floor is quite unlevel or uneven. Legal maximum width of an RV I think is 8' 6" plus appurtenances (things like clearance lights, mirrors, grab bars, and awnings), but you probably want the width of the door somewhat greater so as to make backing in or out less of an exercise in extreme precision maneuvering...doubly so if you don't have plenty of space around to line things up.
Lynnmor
Red Lion
Posted: 03/13/19 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
Be sure to include slideout room plus some extra so you can walk around it. I have two bays with 14' doors and one with a 10' door. I can open my awning to let it dry indoors. If you garage the RV wet, the awning will take forever to dry out if it must stay rolled up. You will never find an owner of a pole barn say he built it too large. Since you are already anticipating adding other toys, I suggest that you build it about twice as big as what you now think you need.
pennrver
Pennsylvania
Posted: 03/13/19 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the great info on here. Sounds like 14x14 doors is the way to go? Or at least definitely 14' height and 12' wide?
As far as depth... I've researched everything from 40 to 60 feet.
Width, how far out do the slides usually come? 3 feet or so? so want to be able to walk around with the slides out? So lets say you have a 14' wide door, with a 8.5' wide coach + 3' + 3' for slides on both sides, your at about 14-15' which is basically the width of the door. So for room on the side, you want your door about 10 feet or so from the side of the barn?
So hypothetically lets say you want a symmetrical barn with 2 identical bays... how much room in between the doors? 15'?
In my example above it would be 10' + 14' (door) + 15' (in between doors) + 14' (door) + 10' = 63'
63' wide seems big, doesn't it? So where do you reduce? In between, on the sides?
Deb and Ed M
SW MI & Space Coast, FL USA
Posted: 03/13/19 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
There *might* be a slight saving in going wider? Fewer vertical posts? I agree with the 16' walls and 14' door height (ours are 12' wide which is more than plenty)
You might add a door or two on the sides, to get things like tractors/trailers in or out without moving the RV
And if you can incorporate a dump pipe into the plan - you'd love it. When we had our pole barn built, the plumber added an extra "clean out" at the front of the building so we could dump the tanks.
K_and_I
North Central Ohio
Posted: 03/13/19 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
So many options, so much cost.[emoticon] We built our barn to hold both the camper and some farm equipment. I went with 12' high sidewalls and wish I would have gone higher. We are locked out of 5th wheels at this point. Remember, if you want an overhead type door, you will need room for it, so a 14' high ceiling will not allow a 14' door. We used full height sliders so we wouldn't lose any more headroom. I don't mind getting out and opening the doors, but some might. We went 40' wide by 64' long. I hadn't intended to go so long, but the salesman showed me how little additional cost there was to adding 2 more 8' bays, and I'm glad I did. At 64' deep, I can leave the truck hooked up to the camper and close the doors with plenty of room to get around it for last minute packing, and it's all hooked up and ready to go in the morning. With the 40' width, I have 2 10' sliding doors, so 20' of opening to hit when I park it. It is nice to have some extra width to be able to work on the camper without running into what ever is parked next to it. You may find, as I did, that going a little bigger does not add as much cost as your first might think.
K_and_I
2011 Rockwood 2604
Nights Camped in 2017: 41
Do we have time for shortcuts?
Page of 7
 > RV Pole Barn
