RV.Net Open Roads Forum: Tech Issues: Safe-T-Alert Propane Gas Alarm
 > Safe-T-Alert Propane Gas Alarm
Merry Bee
Asheville NC
Posted: 03/13/19 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone had issues with Safe-T-Alert going off for no apparent reason? Happened twice last night. We tested with butaine lighter this morning and the alarm works properly. No gas smell. Our Navion is a 2016 so it is under the 5 years replacement suggestion. Just vacuumed and wiped down.
pennysmom09
Delaware
Posted: 03/13/19 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, ours kept going off in our 2015 rig for no reason. The dealership replaced it, no more problemss. We were on the road, so they shipped it to us.
Nancy and Doug
2015 KZ Durango 325RL FW
time2roll
Posted: 03/13/19 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming the battery voltage is fine... you need to replace the detector.
675w Solar pictures back up
wrgrs50s
Scurry, Tx
Posted: 03/13/19 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Mine was doing that and I just unplugged the 12v wires in back of it for a few moments and I guess it reset when I plugged it back in. No more problems.
Walter and Janie Rogers
2012 Sundance 277RL
TV 2006 Silverado 2500 6.0
drsteve
Michigan
Posted: 03/13/19 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Check the date on the detector.
1991 Palomino Filly PUP
1492
Arlington, VA
Posted: 03/15/19 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Posting Help and Support
suprz
rhode island
Posted: 03/16/19 05:47am Link  |  Quote  |  Print  |  Notify Moderator
X2.. The detectors have an expiration date, and it's cheap insurance to just get another. Unless your coach battery is going dead. But that will only make it beep every few seconds, not make it go off. And last but not least, make sure you really don't have a propane leak [emoticon]
Proud father of a US Marine
Lynnmor
Red Lion
Posted: 03/16/19 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a dog?
dougrainer
Carrolton, Texas
Posted: 03/16/19 07:21am Link  |  Quote  |  Print  |  Notify Moderator
1. Voltage fluctuations(12 volt) can sometimes trip a detector.
2. Are you POSITIVE it is a LP only? Most current RV's have a combo CO and LP detector. It will state on the detector
3. The instructions state to NEVER use a BUTANE lighter to test. Never asked WHY. But they do state that. Here is the copy from the manual.
TESTING ! WARNING: DO NOT USE A CIGARETTE LIGHTER TO TEST THE ALARM
4. Other things in the RV can set it off. Hair spray residual Pam cooking spray. ANY spray type can. Perfume and cologne. Doug
PS, When I test I turn on a Range burner and cup up a cup with my hands and then go to the detector and open my hands. The PPM is more than enough to test.
loggenrock
New Hampshire
Posted: 03/17/19 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Being in fire service, I like redundancy! I added an extra smoke alarm, an extra CO detector (with an actual LCD display of parts per million), but I didn't have a second flammable gas detector. Last summer my gas detector likewise activated one day, when it was very windy and warm enough we had windows open. Hmmm.... know it wasn't CO, my second detector had no readings. So, bad detector, or flammable leak? No odor, illogical it would have been detecting gas under moving air conditions. Solved my dilemma by getting a second gas detector. Operates off 5V micro-usb input. About $40. Here's the link: https://smile.amazon.com/Propane-Natural-Detector-Combustible-Explosive/dp/B077XS87LN/ref=sr_1_4?crid=1P6P1KN9L75SD&keywords=propane+gas+detector&qid=1552873722&s=gateway&sprefix=propane+gas%2Caps%2C193&sr=8-4
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
